+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 1
    Points: 1,375, Level: 8
    Join Date
    Jul 2006
    Posts
    34
    Points
    1,375
    Level
    8
    74lvc425
    Hi guys,
    Newbie here. I am trying to interface a microcontroller 3.3 V logic HIGH with 5 V logic HIGH microcontroller. I required to interface 18 parallel pins from 3.3 V to 5 V logic. I used a chip 74LVC425 to do the interfacing. I was wondering is there any easier method to do the interfacing?
    Thanks
    •   Alt26th July 2006, 07:10
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: How to interface 3.3V logic with 5V logic
    If you need to support both directions then the LVC(LVT)245 is the simplest solution ..
    Regards,
    IanP
    •   Alt26th July 2006, 07:57
      advertising
  3. #3
    Member level 4
    Points: 1,862, Level: 10
    Join Date
    Oct 2005
    Posts
    69
    Points
    1,862
    Level
    10
    use line level buffers for 3.3 and 5 volts. As per what ianp said those are line level buffers. Use CMOS going one way and use TTL line buffer going the other way. The thresholds of each do level translations.
    Any other questions let me know
    when going from 3.3 input to 5v output logic use TTL line buffer
    TTL translates anything above 2.4 volts as logic 1 and anything below .5 as a logic 0.
    use cmos going the other way
    •   Alt28th July 2006, 17:27
      advertising
  4. #4
    Member level 5
    Points: 1,628, Level: 9
    Join Date
    Jun 2006
    Posts
    89
    Points
    1,628
    Level
    9
    y can't you use transistor at the output of the low voltage c as a switchof 5V
  5. #5
    Junior Member level 1
    Points: 1,521, Level: 8
    Join Date
    Jun 2005
    Posts
    19
    Points
    1,521
    Level
    8
    try to use serial resistance 200 or 220R between 3.3 and 5V. it may solve the problem.
    •   Alt31st July 2006, 16:34
      advertising
  6. #6
    Points: 1,485, Level: 8
    Join Date
    Oct 2004
    Posts
    Points
    1,485
    Level
    8
    You can use level shifters or translators, many vendors have these ICs. pls check in the web.
