amredries
Member level 2
i am desgin data logger usin pic 16f877 it simply take from current loop ( first i cahnge current level 4-20ma to 0-5 volt by ic called rcv420 ) to its A/d but there is small error when cureent is less than 4 ma the ic give me -ve voltage which the microcontroller read it as zero (i can not make any different betwen 4ma or current less 4ma)
i know that i can't measure -ve voltage but i need to know that the voltage is negative or not so i can display error message
can any suggest a curcuit or code can make this
thanks a lot
thanks a lot
