How to control the brightness of a LED by PWM ?
kit_714
Member level 4
8051 and PWM
Dear All,
How to control the brightness of a LED by PWM in writing program?
Can anyone give me some hints??
If possible, attach some source code for reference...
Really thanks a lot...
Re: 8051 and PWM
kit_714 said:
Dear All,
Control the brightness of a LED isn't difficult because a frequency of 100Hz is enough. A timer should be suitable.
But to control with PWM on the orig. PCB8031 you could use the asynchronous or synchronous output port.
No the 8031 is to old.
by Gomez
Re: 8051 and PWM
I am sorry that i still do not have any idea in program...
can anyone give me some hints on program?
Re: 8051 and PWM
The website attached is using assembly which i am not so familiar...
can anyone give me some source code in c??
Besides, if some hardware configuration can have a better performance, you all can suggest it and attach the circuit diagram to me...
Thanks...
Re: 8051 and PWM
Hi...
just make a lookup table with say 100 entries from 0-99
and use each entry as the on time for a 100ms square wave generated via a timer...
Load the LUT entries into the timer to control the brightness of LEDs (i.e controlling the PWM)
