+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 1
    Points: 2,625, Level: 11
    Join Date
    Nov 2005
    Posts
    104
    Points
    2,625
    Level
    11
    cst pec touching boundary
    Hi
    What is the exact difference between "open" and "open (add space)" boundary conditions ?
    Anyone can help ???
  2. #2
    Full Member level 4
    Points: 3,125, Level: 13
    Join Date
    Jan 2005
    Posts
    199
    Points
    3,125
    Level
    13
    energy balance cst
    both boundary condtions use PML (perfectly matched layer). The "add space" enlarges the calculation box automatically for antenna problems, i.e. radiation patterns.
    •   Alt2nd July 2006, 22:10
      advertising
  3. #3
    Full Member level 1
    Join Date
    Nov 2005
    Posts
    104
    Points
    2,625
    Level
    11
    pec boundary symmetry
    Ok good. Is that mean that I have to specify "open (add space)" for the radiation side(s) ??
    I'm simulating simple antenna structures using CST. The antenna is kind of slot or some other shapes as well. Anyway, I'm getting two kind of errors, and I don't know exactly what they means? and why they appear? and how to overcome this problem.
    1- Some PEC material is touching the boundry ! This may lead to inaccurate farfield results. Please check your structure.
    I have copper not PEC. And it is touching the edge from the port side.
    2- Some higher propagation modes at port 1 are not considered in time domain caculations. This possibly leads to an inaccurate energy balance. Consider to reduce port size or decrease the upper frequency limit.
    •   Alt4th July 2006, 16:22
      advertising
  4. #4
    Member level 1
    Points: 1,975, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jun 2006
    Posts
    36
    Points
    1,975
    Level
    10
    cst boundary condition
    In your structure at the port can propagate some more modes. Try to set more modes in options of port. To problem 1 - It is rather difficult to say something useful without a good illustration.
    •   Alt6th July 2006, 07:52
      advertising
  5. #5
    Full Member level 4
    Join Date
    Jan 2005
    Posts
    199
    Points
    3,125
    Level
    13
    difference between boundaries and concepts
    You should apply "Open (add space)" for radiating directions. Just remember that this is an automatic setting and can be set manually with "Open"+distance of walls under "background properties".
    Referring to the error messages:
    1. Please check that you are using "Normal" background ("background properties").
    2. Use "Open (add space)" for all directions and see if the message reappears.
    3. About higher propagating modes - I agree with demonis, and we can help better if you post the model files here.
    Good luck,
    P.
  6. #6
    Full Member level 1
    Join Date
    Nov 2005
    Posts
    104
    Points
    2,625
    Level
    11
    cst boundary distance z
    Thanks a lot for all of you.
    Please check the following three structures:
    v0: Parallel symmetry planes! No farfield calculation possible.
    v1: Some PEC material is touching the boundary! This may lead to inaccurate
    v2: No error messages. No warnings.
    So, I like to understand what's going on. What is the wrong with CST?
    Regards
  7. #7
    Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2006
    Posts
    36
    Points
    1,975
    Level
    10
    cst,at least one propagation mode is not
    About v1: You have no warnings when you set all boundary conditions to open(add space). Otherwise you have not enough space in calcilation domain for precise farfield calculation
    Added after 1 hours 1 minutes:
    I have also checked vo and v2. In v2 i have the same errors as in vo.
    If you want to calculate farfield you must set boundary condition open ( add space)
    Are you sure that you use in your structure a right mode of CPW-line??
  8. #8
    Full Member level 1
    Join Date
    Nov 2005
    Posts
    104
    Points
    2,625
    Level
    11
    Re: Difference between boundaries- CST
    Thanks a lot.
    I know that I have to set "open(add space)" in the radiation sides.
    Shall I do that for all sides ?? even for x & y ?
    Do you mean by CPW mode, that it should be quasi static mode ? or something else ? I think there is no problem in these cases.
    •   Alt11th July 2006, 10:25
      advertising
  9. #9
    Member level 1
    Achievements:
    7 years registered
    Join Date
    Jun 2006
    Posts
    36
    Points
    1,975
    Level
    10
    You can manually control boundary conditions by settung it in Solve/Background Material/. You can set for x and y directions smaller values as for z direction (only if structure radiates in z direction). If you have a reflector you can set a Zmin smaller as for Zmax.
    In you filed you use a mode like in microstrip line. It is also a mode like a slot line (mode 2 for your case, but i am not sure)
