+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 21
  1. #1
    Newbie level 2
    Points: 1,491, Level: 8
    Join Date
    Oct 2004
    Posts
    Points
    1,491
    Level
    8
    failed to open the tcp port number in the license
    When I start up license daemon with lmgrd,
    I've got error message like as
    " Failed to open the TCP port number in the license. "
    Lmgrd and vendor daemon is not runing at same time.
    I assume that this is kind of OS problem, I use RHEL 3
    have any Ideas?
    root@linux01:/boot> cat /home/proj/rfbeam/stm_lic/v10-lic.log
    14:54:13 (lmgrd) -----------------------------------------------
    14:54:13 (lmgrd) Please Note:
    14:54:13 (lmgrd)
    14:54:13 (lmgrd) This log is intended for debug purposes only.
    14:54:13 (lmgrd) In order to capture accurate license
    14:54:13 (lmgrd) usage data into an organized repository,
    14:54:13 (lmgrd) please enable report logging. Use Macrovision's
    14:54:13 (lmgrd) software license administration solution,
    14:54:13 (lmgrd) FLEXnet Manager, to readily gain visibility
    14:54:13 (lmgrd) into license usage data and to create
    14:54:13 (lmgrd) insightful reports on critical information like
    14:54:13 (lmgrd) license availability and usage. FLEXnet Manager
    14:54:13 (lmgrd) can be fully automated to run these reports on
    14:54:13 (lmgrd) schedule and can be used to track license
    14:54:13 (lmgrd) servers and usage across a heterogeneous
    14:54:13 (lmgrd) network of servers including Windows NT, Linux
    14:54:13 (lmgrd) and UNIX. Contact Macrovision at
    14:54:13 (lmgrd) www.macrovision.com for more details on how to
    14:54:13 (lmgrd) obtain an evaluation copy of FLEXnet Manager
    14:54:13 (lmgrd) for your enterprise.
    14:54:13 (lmgrd)
    14:54:13 (lmgrd)
    14:54:13 (lmgrd)
    14:54:13 (lmgrd) The license server manager (lmgrd) running as root:
    14:54:13 (lmgrd) This is a potential security problem
    14:54:13 (lmgrd) and is not recommended.
    14:54:13 (lmgrd) Failed to open the TCP port number in the license.
    Added after 2 hours 28 minutes:
    solve the problem!
    LMGRD and Verdor Daemon mismatched! that's why it doesn't work!
    I edited LMGRD from V10 to V9.x and then It works fine.
  2. #2
    Newbie level 2
    Points: 1,286, Level: 8
    Join Date
    Jul 2006
    Posts
    Points
    Level
    8
    failed to open tcp port number in the license
    Maybe you need set correct port number and insert statement "USE_SERVER" in you license file.
  3. #3
    Newbie level 1
    Points: 1,741, Level: 9
    Join Date
    May 2003
    Posts
    Points
    1,741
    Level
    9
    flexlm tcp port
    I still meet the problem.
    Can anyone help me
    •   Alt1st November 2006, 09:10
      advertising
  4. #4
    Full Member level 1
    Points: 2,111, Level: 10
    cougar168's Avatar
    Join Date
    May 2005
    Silicon Valley => Shanghai
    Posts
    113
    Points
    2,111
    Level
    10
    flexlm firewall ports
    The port may be taken by other daemons
  5. #5
    Full Member level 3
    Points: 2,957, Level: 12
    Shurik's Avatar
    Join Date
    Jul 2004
    Posts
    167
    Points
    2,957
    Level
    12
    (lmgrd) failed to open any default tcp port
    Hi!!!
    next line is necessary in license file:
    SERVER <Name of server>
    You may to write IP address !
    name of server is necessary to write in /etc/hosts.
    Best regards
  6. #6
    Member level 3
    Points: 1,970, Level: 10
    Join Date
    Apr 2004
    China,SuZhou
    Posts
    58
    Points
    1,970
    Level
    10
    lmgrd failed to open any default tcp port
    if you use the default 27000,it will use from 27001-27009.
    You can see your current port be used by:
    nmap -sT 127.0.0.1
    •   Alt1st November 2006, 13:17
      advertising
  7. #7
    Full Member level 4
    Points: 2,893, Level: 12
    Join Date
    Mar 2004
    Posts
    221
    Points
    2,893
    Level
    12
    Maybe you start 2 or more licenses on one port.
  8. #8
    Junior Member level 2
    Points: 1,425, Level: 8
    Join Date
    May 2006
    Posts
    24
    Points
    1,425
    Level
    8
    Quote Originally Posted by edacw1
    I just want to say so~
    •   Alt27th November 2006, 11:17
      advertising
  9. #9
    Member level 3
    Points: 2,097, Level: 10
    yellff's Avatar
    Join Date
    Apr 2003
    Posts
    58
    Points
    2,097
    Level
    10
    failed to change flexlm license server
    The port can be change.
  10. #10
    Newbie level 2
    Points: 976, Level: 7
    Join Date
    Jul 2007
    Posts
    Points
    976
    Level
    7
    How to edit lmgrd's version?
    Thanks
    2 members found this post helpful.
  11. #11
    Newbie level 2
    Points: 922, Level: 6
    lcbrevard's Avatar
    Join Date
    Oct 2007
    San Jose, CA
    Posts
    Points
    922
    Level
    I just had this problem and FINALLY discovered that if /etc/hosts is missing the
    127.0.0.1 localhost
    line, it causes this same symptom even when EVERYTHING else is OK.
    The previous person administering the system had removed the localhost line for who-knows-what reason!
    OS: CentOS 3.9 (Red Hat Entterprise Linux v3) clone. 32-bit x86 2.4 kernel
    SW: Synopsys lmgrd and snpslmd version 10.9.2 (based on lmgrd 10.8.5).
    License: Synopsys Milkyway MAP-in program
    LCBrevard
    San Jose, CA
    http://brevardandbrevard.com
  12. #12
    Points: 10,814, Level: 24
    omara007's Avatar
    Join Date
    Jan 2003
    Cairo/Egypt
    Posts
    1,238
    Points
    10,814
    Level
    24
    flexlm default port
    How to know if 2 or more licenses are up on the same port ??
  13. #13
    Points: 2,091, Level: 10
    Join Date
    Apr 2002
    Posts
    23
    Points
    2,091
    Level
    10
    failed to open any default tcp port.
    you can use lmstat to check the status of runing dameon.
    and please check the license file, you should see following fomat:
    SERVER hostname hostid port_number
    DAEMON daemon_name path_to_daemon_exe
    # DO NOT REMOVE THE USE_SERVER LINE
    USE_SERVER
    you can change the port_number and restart the license server use following command:
    lmgrd -c you_lic_file -l log_file
    then check the log_file for detail
    Hope this will help you.
    Thanks!
  14. #14
    omara007's Avatar
    Join Date
    Jan 2003
    Cairo/Egypt
    Posts
    1,238
    Points
    10,814
    Level
    24
    flexlm failed to open any default tcp port
    Quote Originally Posted by lovelyic
    USE_SERVER
    Thanks!
    I indeed did that, and when running the lmgrd on the license I got this log file:
    Erased !!! - You have been warned for posting illegal info
    ---------------- TOPIC LOCKED !!! ------------------
    I tried then running the dc_shell-t, and I got the following error :
    Fatal: Design Compiler is not enabled. (DCSH-1)
    I have no idea where is the origin of the problem !! .. the log file looks normal to me except that the last couple of lines with (snmslmd) do have different time stamp that the previous (lmgrd) lines !! ...
    Any explaination to what is happening ?
  15. #15
    Join Date
    Apr 2002
    Posts
    23
    Points
    2,091
    Level
    10
    flexlm port number
    please set following environment variable before run dc shell, below is the bash sample:
    export LM_LICENSE_FILE=27000@localhost.localdomain
    export SNPSLMD_LICENSE_FILE=27000@localhost.localdomain
    where localhost.localdomain is you hostname
    please replace the "(at)" with "@"
  16. #16
    omara007's Avatar
    Join Date
    Jan 2003
    Cairo/Egypt
    Posts
    1,238
    Points
    10,814
    Level
    24
    default flexlm port
    export LM_LICENSE_FILE=27000(at)localhost.localdomain
    export SNPSLMD_LICENSE_FILE=27000(at)localhost.localdomain
    This (at) in my code block is not originally in the file .. this is due to edabaord restriction ..
    For example :
    xyz@123.com is written like the normal email format .. but I believe it will be shown like this : (at) ..
  17. #17
    Member level 1
    Points: 1,457, Level: 8
    Join Date
    Apr 2006
    Posts
    40
    Points
    1,457
    Level
    8
    lmgrd failed to open the tcp port number
    first of all don't run lmgrd with as a root..........check whether you ethernet card is active.........then check for ifconfig which display your ip ....check hostname and mac id in your licenses..........let me know for further ..........
  18. #18
    omara007's Avatar
    Join Date
    Jan 2003
    Cairo/Egypt
    Posts
    1,238
    Points
    10,814
    Level
    24
    failed to open tcp port in license
    Quote Originally Posted by jonnajagadeesh
    so, what's after checking all these things ? .. just checking ??
    •   Alt30th January 2008, 21:53
      advertising
  19. #19
    omara007's Avatar
    Join Date
    Jan 2003
    Cairo/Egypt
    Posts
    1,238
    Points
    10,814
    Level
    24
    lmgrd port
    I'm now getting this new error :
     3:58:50 (snpslmd) Error - lmgrd refused vendor name list.
    This daemon will only serve licenses for the primary vendor.
    Given that I have another version of FlexLM installed on my machine because I installed Cadence long ago before I try to install Synopsys .. and the older FlexLM doesn't work with Synopsys so I had to install a newer version ..
    Any clue to solving this problem ?
  20. #20
    Advanced Member level 1
    Points: 5,152, Level: 17
    Join Date
    Jul 2004
    India
    Posts
    417
    Points
    5,152
    Level
    17
    lmgrd failed to open tcp port
    Hi Omara007,
    I am not any problem with PT. But problem comes only in DC. Did you fix this problem?
