will decouple caps do harm to high speed signals?
newbie_1
Member level 3
hi,
in layout, if decouple caps are under high speed signals which run at the speed of about 2G, will the caps attribute any noise to the high speed signals?
thanks
newbie
Genarally they can. Capacitors and power plate acts like R-L-C circuits, but with different resonant freq. At the point where this two characteristics are cut, you could have peaking. You can find this in Montrose book on this forum.
where do u put the decoupling caps? if u are talking about on the supply or some DC voltage bias, it should help to immune noise.
thanks pixel, do you mean as long as the rlc frequency is far below the frequency of the signals then putting the caps under the signals will be ok?
Read chapter 5-Decoupling:
thanks pixel,
if the cap are under the signals, then the parasitic caps between the signals and the layer of decoupling capacitors will be greater than the that while cap not under the signals?
thanks
