+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 1
    Points: 1,277, Level: 8
    Join Date
    Mar 2006
    Posts
    15
    Points
    1,277
    Level
    8
    Narrow BW (.1%) CombLine Filter
    Is it possible to design a combline filter with <.1% BW (e.g. 12 MHz BW @ 12GHz)?
    •   Alt29th June 2006, 00:06
      advertising
  2. #2
    Member level 1
    Points: 2,385, Level: 11
    Join Date
    May 2006
    Poland
    Posts
    33
    Points
    2,385
    Level
    11
    Theoretically yes
    •   Alt29th June 2006, 14:43
      advertising
  3. #3
    Newbie level 1
    Points: 1,135, Level: 7
    Join Date
    Aug 2006
    Posts
    Points
    1,135
    Level
    7
    Re: Narrow BW (.1%) CombLine Filter
    I think it is possable
    •   Alt17th August 2006, 03:08
      advertising
  4. #4
    Advanced Member level 5
    Points: 33,048, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,639
    Points
    33,048
    Level
    44
    Practically, no. A filter usually has a need for a low insertion loss, flat passband, and defined in-band riple. When you take an ideal prototype and try to make it into an actual real life filter, the Q of the filter elements tends to distort the passband so much that it looks nothing like the prototype prediction.
    Now, if allyou want to do is pass a single frequency and reject out of band stuff by as much as possible, and you do not care too much about insertion loss, then yeah, you can make a narrow filter at 12 GHz. A single dielectric resonator puck losely coupled will do the job nicely.
    I suppose you could use a saphire resonator or superconductor resonator and end up with superhigh Q elements that could do the filter job, but that is more science fair than engineering.
  5. #5
    Advanced Member level 3
    Points: 13,776, Level: 28
    Join Date
    Feb 2002
    Posts
    749
    Points
    13,776
    Level
    28
    Temperature stability may be an issue at this narrow bandwidth. Usually a frequency conversion to a lower frequency is required prior to narrow band filtering, giving a larger relative bandwidth. For example, at 240 MHz, 12 MHz BW is 5 %.
    Quote Originally Posted by Krytar
    •   Alt17th August 2006, 23:11
      advertising
  6. #6
    Join Date
    Mar 2006
    Posts
    15
    Points
    1,277
    Level
    8
    Thanks VSWR.
    I did design the filter, and it worked.
    My concern is its performance over temp.
    I used cold rolled steel for my resonator, and a silver plated aluminum housing.
    Unit was plugged into a sub assy after I built it so I didn't have any chance to test over temp.
    I'll build another unit to test over temp to see its performance.
    Regards
    Krytar
