Looking for temperature monitoring program for Linux
asueee0
looking for the following linux based program:
1. temperature monitoring program
2. overclock program which could adjust cpu (AMD 64) core voltage and multiplier without rebbot
linux temperature log
asueee0 said:
looking for the following linux based program: temperature monitoring program
What must this program do? Log to disk, display data on a graph, ...
What kind of temperature sensors will be used and how will they be interfaced to the linux-based cpu?
linux, temperature software
I found this site :
http://distrowatch.com/dwres.php?resource=review-kanotix
further in the site I found
If you have a laptop with a Centrino or AMD64 processor, you may want to use rcconf to enable powernowd, a fantastic power-management daemon. I started powernowd and watched in amazement as my CPU temperature dropped by 15 degrees Celsius in 10 minutes.
This might be a good time to point out just what tool I use to find out the CPU temperature. I use (drumroll please) gkrellm, which actually reports a number of interesting things about your setup. In its default configuration, gkrellm doesn't display CPU temperature, but you easily make it do so by right-clicking on "CPU" and choosing "Sensors--> Temperature" and clicking the box saying "thermal_zone/THMO".
maybe it will help a bit.
edit:
got this aswell, didn't test though.
http://rpmseek.com/rpm-pl/cpuinfo.html?hl=com&cs=cpu:PN:0:0:0:0
Package Name cpuinfo
Summary This applet shows the current CPU temperature and frequency
linux temperature stats
Try gkrellm for temperature statistics display. You need to configure the underlying lm_sensors (or equivalent) engine however.
