+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 4
    Points: 3,157, Level: 13
    rakesh_aadhimoolam's Avatar
    Join Date
    Mar 2006
    Posts
    206
    Points
    3,157
    Level
    13
    virtual short op amp
    i am electrical engg. i am new to this op-amp world. i would like to know what exactly a VIRTUAL GROUND refer to........
    thanks
    •   Alt20th June 2006, 08:47
      advertising
  2. #2
    Full Member level 2
    Points: 2,567, Level: 11
    Join Date
    May 2006
    Posts
    142
    Points
    2,567
    Level
    11
    meaning of virtual ground in op amp
    I/p impedance of an opamp is very high and hence very little current flows thru it's inputs and hence very little voltage drop occurs at i/p.Hence if one of it's i/p is grounded ,since voltage difference b/w two i/ps will be very less we can assume other one of the i/p also to be at ground and hence giving rise o term 'virtual gound'.
    •   Alt20th June 2006, 09:19
      advertising
  3. #3
    Advanced Member level 2
    Points: 4,836, Level: 16
    Join Date
    Aug 2005
    Posts
    605
    Points
    4,836
    Level
    16
    virtual ground in OP AMP
    virtual ground ... there r two inputs to an Opamp now
    whatever voltage is present at 1 input ...same is assumed to present at 2nd input too!
    this concept is very vital ..
    •   Alt20th June 2006, 10:22
      advertising
  4. #4
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: virtual ground in OP AMP
    Similar explenations you can find in the Wikipedia:
    http://en.wikipedia.org/wiki/Virtual_ground
    In general, the concept of "virtual ground" has wider meaning than the above ..
    Sometimes it is called a "rail splitter": it splits a single supply in two, so you have two "voltage rails" plus "new" ground - the virtual ground ..
    Here you will find more:
    http://tangentsoft.net/elec/vgrounds.html
    Regards,
    IanP
  5. #5
    Member level 5
    Points: 1,581, Level: 9
    Join Date
    Nov 2005
    Posts
    90
    Points
    1,581
    Level
    9
    Ideal opamp gain is high. It makes the two input equal.If one input is connected to ground,the other is virtual ground
    •   Alt20th June 2006, 11:23
      advertising
  6. #6
    Member level 3
    Points: 1,774, Level: 9
    Join Date
    Feb 2005
    Posts
    63
    Points
    1,774
    Level
    9
    due to -ve feedback the -ve terminal approaches the +ve terminal since the gain of opamp is in 1000's .we say the -ve terminal of opamp is at virtual gnd (virtual since not really grounded)if +ve terminal is at gnd.
    1 members found this post helpful.
  7. #7
    Member level 3
    Points: 1,699, Level: 9
    sachinagg77's Avatar
    Join Date
    Jan 2006
    Japan
    Posts
    64
    Points
    1,699
    Level
    9
    The op-amp has two input terminals. When the op-amp is used with some negative feedback around it, the two input terminals are at same potential [ideally], although they are physically not connected together. This is referred to as VIRTUAL SHORT [and NOT virtual ground]. In case one of the terminal is kept at GROUND Potential, then the other one is also at GROUND Potential. This can be referred to as VIRTUAL GROUND.
  8. #8
    Full Member level 5
    Points: 2,733, Level: 12
    Join Date
    Jun 2006
    Posts
    244
    Points
    2,733
    Level
    12
    Both the inverting and non inverting inputs of an opamp are bootstrapped to each other. If one is set to a certian voltage the other input will follow......
