Find the S parameters(2 port for differential/1port for single ended) using a network analyzer. The S parameters can be converted to Y/Z parameters. You can start of with a simplified model for the inductor, say a pi model with series resistor, and parallel caps. Try to map the Y/Z parameters to the pi model and extract the inductor,series resistance,parallel parasitic caps and hence Q and self resonant frequency.
