How to synchronize data or signal from different clk domains
Re: How to synchronize data or signal from different clk dom
use a FIFO to write at one clock and read using another clock. there by u can syncronize
Hello sycolegend.
can u just tell one thing that is your signal coming from fast clock domain to slow clock domain or vice versa.
You can also use control signals originating from the domain the data is in . Synchronize using double FFs the control signal in the other domain and only then take the data in the other domain. Need to make sure that the data does not change after control signal is set in the first domain however.
    sycolegend
spauls said:
Hello sycolegend.
Hi, spauls
In my design, both the two sides need signals from the other side.
let try to write two process in the architecture................
use a fifo or if you are using VHDL try to generate all the clocks from one big sorce clk.
If this is the case than handshaking is the best technique.
you can use the pulse synchronizer also
two method ,1,you can use fifo.2,you can use two FF
to aynthronize the signal
