Schematic...Circuit Diagram for USB-to-USB PC connection
xischaune
Full Member level 1
usb circuit diagram
Hi all...
does any one have any circuit diagram/schematics for connecting two PCs through USB port...
Thanx in advance...
circuit diagram of usb
interconnection between two PC's via USB is based on TCP/IP. It's not ordinary wiring. And available products are very slow, about 6Mbit/s. Theoreticaly it could be possible e.g with two PIC 18F4550 and using parallel. But this is madness, I think.
This is only one complete solution which i have found:
Datasheet:
18f4550 pc connection via usb software
is probably better to use ethernet instead
circuit for usb ethernet adapter
Use ethernet.
18f4550 usb ethernet
... or two FTDI USB-to-UART chips.
This is not necessarily madness. Such device can be used to simulate a USB device, which doesn't yet exist, with a PC.
diagram of usb ethernet connections
Helloooo..
About your question, USB host to host communication.
Take a look at these possible solutions.
https://www.usbgear.com/item_100.html
# USB host to host communication
# High-speed data transfer rate up to 8Mbps max
Price= $28.90
https://www.usbgear.com/item_143.html
# TCP/IP ,NetBEUI, IPX/SPX
# Maximum Data transfer rate: Over 5 Mbps.
# Construct USB Network up to 17 PCs
Price=$39.50
And 3rd, in case one of your PC has an Ethernet port.
https://www.usbgear.com/item_130.html
The USBG-110T USB Ethernet Adapter provides an easy way to connect a USB-enabled desktop or laptop PC to a 10/100BaseT Ethernet LAN. It comes with an attached USB cable that has a type A plug for standard USB connection to PC's USB
Price=$33.50
Hope that helps.
JR
usb to uart circuit diagram
The problem with USB is the software and the drivers. With ethernet, you can use simple TCP/IP based software that every PC has.
usb ethernet adapter schematic
How i use MC68hc908JB8(Usb moto) ?
