ATPG question about Check PO mismatch & Check SO mismatc
emma_happy
Newbie level 1
on ATPG?
I can understand the first 3 cycle only. It's shift registers.
but I was confused by the "Check PO mismatch" & " Check SO mismatch" item.
and what does the "RE" mean?
Re: on ATPG?
"Check PO mismatch": Compare the primary outputs with correct values
" Check SO mismatch": Compare the scan-chain outputs with correct values
