[PLL] Relation between Freq Step and Phase Step response?
yolande_yj
Full Member level 3
pll step response
Hi, in PLL design, what is the relation between frequency step response and phase step response?Or what is the relation between Freq(ω) and Phase(ω)? Thanks
what is a pll step response
the frequency step is a ramp in phase ,
so the phase step is differnitation of frequncy step"which is ramp in phase"
so to get frequncy steo respose "apply a step" then put an integrator before the pll
khouly
Re: [PLL] Relation between Freq Step and Phase Step response
integration?
How can I apply a phase step?
if u use a linear model in s domain , just use a step source , this will be the phase step
khouly
how about in time domain, transient simulation?
Dear Yolande,
In a PLL, you can actually inject the phase step by adding a source at the input of VCO in the PLL, in series with the loop filter output. Remember that the the control voltage will determine the phase/frequency
Vamsi Mocherla said:
Dear Yolande,
Yes, but if I apply a voltage step to the VCO, that will cause frequency step, not phase step.
i never did this before but u may try it ,
1- try to do a model for a source like
V=A*sin(w*t+phi) ; the source get the phi as input "i think it is a simple verilogA code"
then just add a step to the phi i/p.
i didnt try this but it may work.
