How to connect JDM programmer to the parallel port
pic-novato
Member level 2
Lima - Peru
Hi
I need to conect a JDM programmer in the parallel port, i try with Ic-prog but only have the option with serial port. Is possible?
Somobody knows what can i do?
Other software?
Thanks in advance.
Re: JDM in parailel port
JDM programmer works only on serial port!!!
Cristi
Hi cristi:
I think the same but take a look the diagram, the number in the labels is the pin of parallel port, and in the right i put the pins for serial ports.
Originaly the JDM was made for parallel port, see this link.
JDM is definitely for serial port.
RS232 connectors come in 2 types: 25-pin and 9-pin. What you see in the labels is for the 25-pin RS232 connector, and what you see in the skinny box is for the 9-pin RS232 connector.
Cheers,
Pin number are for connector with 25 pins, but serial (male). See this page:
hxxp://www.beyondlogic.org/serial/serial.htm
Here you will find a parallel port programmer:
hxxp://www.olimex.com/dev/images/pic-pg3b-sch.gif
Cristi
