Why is the mobility of the electrons is greater than holes?
rsjgs
Newbie level 5
mobility
How is that the mobility of the electrons is greater than that of the holes? Holes basically arise due displacement of electrons right?
mobility
the problem is that when u say holes u mean electrons in valece band while when u say electrons u mean electrons in conduction band , this implies that "holes" mobility is lower than "electrons" mobility
Re: mobility
Mobility has an inverse relationship to the charge's effective mass. Since electrons have a lower effective mass than holes, its mobility will be higher.
Re: mobility
Yes, sorry, correction:
Holes have a higher effective mass than the electrons, so the electron's mobility is higher!!
At low electric fields :
Re: mobility
Mistico_Pereyra said:
Holes have a higher effective mass than the electrons, so the mobility is higher!!
higher eff. mass is lower mobility (i.e. heay bodies move slower than lighter ones)
Re: mobility
hole movement is usually characterised by jumping of an electron bound to an atom to an adjacent vacant space, resulting in a vacant space in the original location of the electron. this vacant spot is the hole, which drifts slowly jumping between adjacent slots only, whereas a free electron, as the name suggests, drifts freely and moves faster. so we say holes have less mobility
