+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Junior Member level 2
    Points: 1,570, Level: 9
    Join Date
    Jan 2005
    Posts
    21
    Points
    1,570
    Level
    9
    difference between laplace and fourier transform
    What are the differences?
    I mean when we will make a decision "hmm now i must use laplace transform or now i must use fourier transform".
    What are the absences in laplace transform so fourier design a new transfom?
    I want to know these transforms' main idea, differences.
    I am looking for your answers.
    Thanks .
    Sincerely;
    •   Alt23rd May 2006, 09:17
      advertising
  2. #2
    Advanced Member level 2
    Points: 6,801, Level: 19
    Join Date
    Nov 2004
    Tamilnadu
    Posts
    659
    Points
    6,801
    Level
    19
    laplace vs fourier
    for all signals we can have laplace transform but we can have fourier transform only for ceratin cases...Fourier transform needs certain conditions caled as Dirchlet conditions whereas laplace wont need anything like this....
    1 members found this post helpful.
  3. #3
    Join Date
    Jan 2005
    Posts
    21
    Points
    1,570
    Level
    9
    Quote Originally Posted by electronics_kumar
    Can you explain this concept please?I need some details..
    Thanks...
    •   Alt23rd May 2006, 11:07
      advertising
  4. #4
    Newbie level 3
    Points: 1,261, Level: 8
    Join Date
    May 2006
    Posts
    Points
    1,261
    Level
    8
    fourier vs laplace
    Quote Originally Posted by serimc
    Thanks...
    http://lofi.forum.physorg.com/Laplac...urier_403.html
    http://www.dsprelated.com/showmessage/39243/1.php
    http://www.physicsforums.com/showthread.php?t=40770
  5. #5
    Full Member level 3
    Points: 2,487, Level: 11
    Join Date
    Dec 2004
    Iran
    Posts
    152
    Points
    2,487
    Level
    11
    laplace vs. fourier
    in a simple expression:
    Laplas Transform does a real transformation on complex data but Fourier Tranform does a complex transformation on real data.
    it means:
    L(σ1+jω1)=σ2+jω2
    F(ω1)=|ω2|<ω2
    at the presence of some condition you can take the Fourier transformation by placing instead of s in Laplas tranform.
  6. #6
    Points: 1,209, Level: 7
    Join Date
    May 2006
    Posts
    Points
    1,209
    Level
    7
    laplace vs fourier transform
    theoretically..laplace represents σ + jw and is in all of the s-plane while in fourier its only in the jw axis of this s-plane..so basically we are setting the real part of the exponenntial to 0 and hence
    it will give you the features for steady state for a sinusoidal input
    and in the case of laplace it will tel u for rising or fallin sinusoidal.
    i hope that shud answer ur question..
    2 members found this post helpful.
    •   Alt23rd May 2006, 16:01
      advertising
  7. #7
    Advanced Member level 1
    Points: 3,875, Level: 14
    Join Date
    Mar 2006
    Culiacán, Sinaloa, Mexico
    Posts
    479
    Points
    3,875
    Level
    14
    laplas transform
    For a good explanation you can consult the book PLL, or Roland E. Best, that you can find in this forum.
    As my colegees said Laplace transform translate f(t) to σ + ωi domain, while Fourier translate f(t) to w domain.
    that means Laplace has information of time and frequency that's why we use to study transitory circuits. But Fourier dosn't have all the information i this case fase and wave forms only frecquency and amplitude.
  8. #8
    Join Date
    Nov 2004
    Tamilnadu
    Posts
    659
    Points
    6,801
    Level
    19
    fourier versus laplace
    Quote Originally Posted by shivamrules
    for lapalce transform, it is (σ + jw) when you are going to Fourier transform it become (0 + jw )..i mean σ =0 no attenuation in the system...
