hurricane
Newbie level 5
I need to make a current detection circuit for a Diode. and please help me to find a IC or a good circuit to detect the current.
a brief description is:
The cathod of the diode is GNDed via a current source and the anode of the diode is connected with Vcc directly. the purpose of the detection is check whether the diode is broken down or not.
the current via the diode is about 20mA to 50mA, and the on/off frequency of the current source is about 8MHz(a PWM signal).
In my opinion, to detect current is a good way to check the diode. and I have two idea to do so.
1 via a R.
2 via a Hall-Effect whose output is a function of a mag flux senor. and the mag flux is a function of the current.
would you give me some hints and advice to create this kind of circuit or use another method to check whether the diode is functional.
Thanks well.
1 via a R.
Thanks well.
