Fatal error in VHDL: can't open a file in rb mode
emmos
Member level 2
hello
I am writing a vhdl program for reading text files and i run it in modelsim but it gives me the following error
** Error: (vsim-7) Failed to open VHDL file "hds_projects/my_project2/my_project2_lib/hdl/file_io.txt" in rb mode.
# No such file or directory. (errno = ENOENT)
why???
plz help
i attached the vhdl code
thanks
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
LIBRARY std;
USE std.TEXTIO.all;
ENTITY file_io IS
END ENTITY file_io;
ARCHITECTURE test OF file_io IS
signal done : std_logic := '0'; -- flag set when simulation finished
begin -- test of file_io
done <= '1' after 5 sec; -- probably set via logic, not time
read_file:
process -- read file_io.in (one time at start of simulation)
file my_input : TEXT open READ_MODE is "hds_projects/my_project2/my_project2_lib/hdl/file_io.txt";
variable my_line : LINE;
variable my_input_line : LINE;
begin
write(my_line, string'("reading file"));
writeline(output, my_line);
loop
exit when endfile(my_input);
readline(my_input, my_input_line);
-- process input, possibly set up signals or arrays
writeline(output, my_input_line); -- optional, write to std out
end loop;
wait; -- one shot at time zero,
end process read_file;
write_file:
process (done) is -- write file_io.out (when done goes to '1')
file my_output : TEXT open WRITE_MODE is "hds_projects/my_project2/my_project2_lib/hdl/file_o.txt";
-- above declaration should be in architecture declarations for multiple
variable my_output_line : LINE;
begin
if done='1' then
write(my_line, string'("writing file"));
write(my_output_line, string'("output from file_io.vhdl"));
writeline(my_output, my_output_line);
-- write(my_output_line, done); -- or any other stuff
end if;
end process write_file;
END ARCHITECTURE test;
modelsim failed to open file in rb mode
It appears to me, there is no problem with your code. It seems that you don't have created the file you are trying to read, or it isn't located in the path you are indicating.
failed to open vhdl file in rb mode
read modelsim tutorial it helps u to do small project step by step
good luck
rb mode+modelsim
i guess u should be sure what permissions you have on the file...if u did create it
also, there maybe a problem with the path...
it is a tiny problem...i hope u can solve it soon
feed us back with what u did
Salma
:D
failed to open vhdl file in rb mode.
Your problem seems to be that you are using a relative directory path that is relative to the wrong place.
You should either specify an absolute path name (yuck), or you should reference it from the 'work' directory that the ModelSim compiler creates.
i.e. if the work directory is in:
hds_projects/my_project2/work
you should 'cd' ModelSim to:
and your path name should be:
hdl/file_io.txt
Cheers,
Blowfishie
failed to open vhdl file hex in rb mode
dear all,
i still have a problem so i decided to do a smaller program
LIBRARY ieee;
LIBRARY std;
USE std.TEXTIO.all;
ENTITY file_io IS
END ENTITY file_io;
ARCHITECTURE r_w_file OF file_io IS
BEGIN
try: process
file ini_file : text open read_mode is "C:/hds_projects/test1/test1_lib/hdl/in_file";
file outo_file : text open write_mode is "C:/hds_projects/test1/test1_lib/hdl/out_file";
variable in_line,out_line : LINE;
variable half : INTEGER;
begin
wait;
while not (endfile(ini_file))
loop
readline (ini_file,in_line);
read (in_line,half);
half := half/2;
write (out_line,half);
writeline(outo_file,out_line);
end loop;
end process try;
END ARCHITECTURE r_w_file;
I put the file in that path the file is named in_file and it contains a no. 22 for reading
the modelsim
it gives me this error
# ** Error: (vsim-7) Failed to open VHDL file "C:/hds_projects/test1/test1_lib/hdl/in_file" in rb mode.
# Time: 0 ns Iteration: 0 Instance: /file_io
i have read somethings about putting $ infront of the path????
plz help
vhdl writeline
Hi emmos,
This should work...
Are don't you have any extension to your files (.txt, .bin, .hex, ....) ?
give extension as .txt and move the file to other location on inside hds_projects..
and edit the code according to that..
it will work
Regards
Shankar
May be it is that MTI under Windows uses "\" as directory separator. How about using simple file name such as:
file ini_file : text open read_mode is "in_file";
And make sure you have this file in the curent working dir where you launch MTI from?
Ajeetha, CVC
www.noveldv.com
New Book: A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
https://www.systemverilog.us/
modelsim failed to open file in read mode
i dont know if this is true or not, but me myself, never specify a path... i just write ie:
file my_input :
TEXT open READ_MODE is "io.txt"; and then put the file in the same path as other project files....ofcourse i complie everything from ISE7.1 and dont know the exact process of doing it in modelsim....
