sjjm
Junior Member level 1
using lm35 on pic 16f872
hello
nid some. I am usin a sensor lm35 to measure temperature and feeding this to a pic 16f872 thru RA0 which is an A/D port. Is it ok if i directly input the voltage from the sensor to the pic. The voltage is in mV e.g a temperature of 26 degrees gives a voltage of 260mV. Am tryin to avoid an amplifier.
Also if someone can help me with the neccessary code to do the measurement. I also need to display theis temperature on two 7 segment LED displays.
help
hello
help
