Read - Write a file from physical disk by VHDL
kangta
Junior Member level 2
Plz ! help me ....
I got a problem that makes me confusing . I must write a program that can read and write data from a physical disk by VHDL and simulate by Max+Plus II . But I can't write by Max+Plus II . It 's error ..... So , How can I write ..................
Can you show me more e_books write about that .....
Check out the textio library.
    kangta
for this the entity should be considered as the basis of textio package
thank for ur helpings .......... I will try......
include ieee.textio.all
use file is in "file name"
read()
readlin("l");
use file is out "filename"
Write();
writeline();
check vhdl baskar book for further references.
REgards
Shankar
Tallika
Oh thank for all ur help .....
but a new problem occurs that MaxPlus doesn't support for access type that the most important tool for access line string so.........
Are you trying to get the FPGA to interface to the disk or just with the simulator?
You cannot synthesize any textio functions.
Cheers,
Blowfishie
Oh.....
I do this job just to simulate for acknowledge >..... but with altera I can't do any simulation because they don't support acess type so we can't use the pointers.....
Hi kangta
Check the MaxPlusII help :
File I/O cannot be synthesized; therefore, calls to TEXTIO functions are ignored.
