cverrcv
Newbie level 3
You will probably wont believe it but this is realy the problem that I need to be solved.
I have a very high voltage DC source that I need to be converted in 220 VAC 60Hz.
The DC source is 10kv DC at 50 amps.
I would like to have a sort of power inverter or converter that would use this high DC voltage from the source to convert it to a standard 3 wires (2 hot wires with a neutral) 220 volts AC with an absolutely pure 60hz sinusoidal wave form of a very high stability.
The output power needed is between 2kw to 100kw.
Thus, I need the circuit to be extremly simple and easily scalable. I mean that the circuit can be designed to sustain only 2Kw if it can be easyly scalable to sustain 10Kw if and/or when needed. Probably by just having to add additional output transistors in parallel or transfo or whatever will be needed.
This is a very seriuous request, not a joke.
Thanks in advance to all those who will take their time to help me by providing a schematic that I will have to follow to built such a circuit.
Regards
Regards
