+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 3
    Points: 1,609, Level: 9
    Join Date
    Apr 2005
    Posts
    28
    Points
    1,609
    Level
    9
    glue gun pcb components
    What is the melting point of the glue (poured using glue gun) which is normally used to stick components in the PCB to hold firmly.
    If i give the PCB for a temperature test subjected to 80 degree centigrate, will the glue melt away?.
  2. #2
    Full Member level 3
    Points: 4,441, Level: 15
    Join Date
    Apr 2001
    Posts
    155
    Points
    4,441
    Level
    15
    melting point of glue
    There are several temperatures at which Glue Sticks (the sticks used in the glue gun used to secure PCB components) will melt at.
    It depends on the colour of the stick (glue) to say what temperature it will melt at.
    It also depends for how long you will apply 80 deg C for (I assume you are doing a soak test).
    I would suggest that (if possible) you could scrape some glue and then melt it on tissue paper (or some other type of paper) and note the melting temp.
    If your PCB is a military PCB you should be ok but I would not take risk with a comercial board.
