Did anyone build two seven segments up\down counter?
hassan1980
Full Member level 4
i built it using FPGA programming
    hassan1980
do u want it to do using microcontroller or without it. i have both the methods. it is very simple.
multiplexing two 7-seg displays with pic 16f84:
www.mikroelektronika.co.yu/english/product/books/PICbook/7_08chapter.htm
hassan1980 .. Assalamo alaykom,
I think this is one of the best solutions you have to try !
Very simple to build, and to debug...
Bettawfeek,
Ahmad,
i made one using only logical operators , logical nand , nor etc ...
ok , u can use bistables to do it ,its very simple , look at the pics , it uses 4 jk bistables to get ur number into 4 digit , then u can use any transcoder to get it working on a 7 segment.
i'm joining here also the 74ls192 (an up down counter ) datasheet .
if u need anything else just tell me and i'll try to make complete schematics for u (when i have some free time ). but i think if u search for it u will find what u want .
go for two 74190 if u want BCD counting or go for 74169 for binary counting. See the datasheets of these IC's then u will get how to do it
