+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Member level 1
    Points: 1,579, Level: 9
    Join Date
    Apr 2006
    Posts
    41
    Points
    1,579
    Level
    9
    non-manifold edges hfss
    I've a problem in HFSS.
    When I run the validate process the message viewer returns this error message:Non-manifold vertices found for part "layer" where "layer" is a part of the model.
    The model is a transceiver on FR4 made from a 4 layer structure and the "layer" part is in the middle between the others.
    What does this error means?
    Thanks in adv.
    •   Alt28th April 2006, 08:27
      advertising
  2. #2
    Member level 1
    Points: 1,367, Level: 8
    Join Date
    Apr 2006
    Posts
    40
    Points
    1,367
    Level
    8
    non-manifold vertices hfss
    sorry, cannot catch your word.
  3. #3
    Advanced Member level 1
    Points: 3,555, Level: 14
    Join Date
    Aug 2001
    Posts
    414
    Points
    3,555
    Level
    14
    non-manifold vertices found for part
    HFSS is complaining that the geometry "layer" you draw is not valid. Try different ways of drawing.
    •   Alt28th April 2006, 15:35
      advertising
  4. #4
    Member level 3
    Points: 1,772, Level: 9
    Join Date
    Apr 2005
    Posts
    63
    Points
    1,772
    Level
    9
    hfss error messages
    The error message indicates there is a problem with the mesh. This could happen if you imported the geometry from a CAD tool. You may need to re-draw that part of the model. See the link below for more info:
    http://www.ansoft.com/ots/tekboard_m...d=1633&line=HF
  5. #5
    Junior Member level 2
    Points: 1,357, Level: 8
    Join Date
    Oct 2005
    Posts
    23
    Points
    1,357
    Level
    8
    You can plot orther geometry instea of "layer",such as model.
    •   Alt1st May 2006, 01:37
      advertising
  6. #6
    Newbie level 2
    Points: 1,057, Level: 7
    Join Date
    Jan 2007
    Posts
    Points
    1,057
    Level
    7
    hfss non manifold edges
    I have he same problem; an error message says "no manifold vertices found".
    I don't thing that there is another way to draw my model.
    Could anyone help me?
    Thank you.
    macala
  7. #7
    Member level 2
    Points: 2,236, Level: 10
    heedavid's Avatar
    Join Date
    Apr 2005
    Posts
    52
    Points
    2,236
    Level
    10
    non manifold edges hfss
    Actually, I'm not sure whether I'm right.
    But I was told that; if you're confident that you've drawn your structure in correctly, and you still get the above-mentioned error message. You can high-light the troublesome objects and do the HFSS option called "Heal Objects".
    Try it! It might work, you'll never know! By the way, I think the message sometimes pop up when you have 2D objects sharing a common edge, or a loop within a loop. Hope these help.
    BR,
    Dave
    1 members found this post helpful.
  8. #8
    Newbie level 2
    Join Date
    Jan 2007
    Posts
    Points
    1,057
    Level
    7
    non-manifold edge hfss
    Hi!
    Thanks a lot for your help.
    I have a new problem now. I did the validation check and all was right, so I started the analysis, but during the initial mesh operation the simulation stops and a new error message appears: "Initial mesh, process mesh3D: error while opening or writing the mesh files".
    Please, help me again!
    Macala
