SOC Encounter: .v file is a verilog or synthesized verilog?
p_shinde
Full Member level 5
tokyo
SOC Encounter
hi,
one of the inputs given to SOC encounter is the .v file, is this a verilog file or synthesized verilog file ?
reply soon, thanks in advance
Prasad
Re: SOC Encounter
this is usually a netlist file. along with this, u ll be given lef files for hardmacros(usually memories i suppose) and lib files. using these files, the backend process starts.
SOC Encounter
yes its a synthesized verilog file
SOC Encounter
The .v file is verilog netlist file. It is a synthesized file.
Re: SOC Encounter
Yes its synthesized verilog netlist
Re: SOC Encounter
it can be gotten from synopsys dc or rtl compiler or buildget ..
Re: SOC Encounter
For SOCE 4.2 and before, the design must be given in Verilog gate-leve netlist for P&R.
From SOCE 5.2, it has integrated RTL Compiler(RC) inside.
So you can also give the design in Verilog RTL code for logic synthesis.
Re: SOC Encounter
If the SOC Encounter synthesis RTL codes, will the builtgates be abandon?
