+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 1
    Points: 1,283, Level: 8
    Join Date
    Apr 2006
    Posts
    16
    Points
    1,283
    Level
    8
    interruptual
    i am looking for someone who has a tried and working circuit for a zero crossing detector which can be interfaced to a pic
    •   Alt17th April 2006, 15:09
      advertising
  2. #2
    Newbie level 3
    Points: 1,210, Level: 7
    Join Date
    Apr 2006
    Posts
    Points
    1,210
    Level
    7
    zero crossing detector circuit
    hi..
    you can use an OPAMP 741 for zero cross detector.
    1 members found this post helpful.
    •   Alt17th April 2006, 15:16
      advertising
  3. #3
    Full Member level 1
    Points: 2,214, Level: 10
    Join Date
    Apr 2006
    Under Mango Tree
    Posts
    95
    Points
    2,214
    Level
    10
    Re: zero crossing detector circuit
    this is the circuit of zero cross detection with a pic port.
    •   Alt17th April 2006, 18:53
      advertising
  4. #4
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Here are some other examples of zero crossing detectors ..
    Regards,
    IanP
  5. #5
    Advanced Member level 1
    Points: 6,829, Level: 19
    Join Date
    Feb 2005
    Posts
    427
    Points
    6,829
    Level
    19
    Have a look at microchip application note AN958.
    www.microchip.com
    Good luck.
    •   Alt18th April 2006, 09:33
      advertising
  6. #6
    Junior Member level 2
    Points: 1,622, Level: 9
    hjamleh's Avatar
    Join Date
    Oct 2005
    Taiwan
    Posts
    24
    Points
    1,622
    Level
    9
    It is easy man, think about this... each leg of microcontroller has two protection diodes (zener), if the applied volatge is over 5 volt, let us say 220 Vrms, then the zener will cut it to 5 volt, and if it is -220Vrms, then the another zener will work in forward and make the volatge almost zero.
    What you need is high impedence resistor (100Mohm) connected from the source (220Vrm) directly to the PIC interrupt leg, or you can use non-interruptual method just by scanning that pin if the frequency is not very haigh.
    You need some protection and noise remover circuits.
    *** It is hazardous but will cost you nothing!!
    Good luck
    Hani
