Schema III printer question
Pat Appleson
Newbie level 1
omation schema
I've been using Schema III by Omation for years. I have lots of files that we refer to and would rather not "upgrade" at this time. Yes, I also use the slighty new stuff from Accel too.
But back to the problem. I can't make it print under XP. A few versions back I could get it to print in the "Schplot" mode under win2k. Just shell out to DOS and give it a command line like: schplot filename.p45 /r /e /0=lpt1 It would take off and print the page very nicely.
I've tried many things to make it work, but finely gave up on XP. So now I have a PC with just MS DOS 6.22 installed and the Schema program. BTW, I can view and edit the skats in XP but can't make them print. Mainly because we got a new monster xerox network printer that has no parrell port. Just USB and LAN.
So, it looks like I need a printer that will emulate Laser Jet III with a paraell port to attach to the DOS pc's port.
Does anyone have a better idea? Is there some software out there that will trick schema III to get it to print out to a USB printer?
Help
Best Regards
Pat
www.appleson.com
omation schema iii
I've had good luck with "printing" to a file with the Postscript driver. I then use Ghostview or something similar to print under XP.
Very good resolution and seems to work with all usual printers.
Good luck!
John
www.JSTtech.com
schema iii on xp
Hi Pat,
I can offer to convert your SCHEMA III files to PCAD or Altium Designer.
John
www.JSTtech.com
Help
Best Regards
Pat
www.appleson.com
