+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Full Member level 3
    Points: 2,181, Level: 10
    Join Date
    Apr 2005
    Posts
    168
    Points
    2,181
    Level
    10
    monitor goes red
    My monitor goes RED???
    Whenever I start my computer, it loads normally..but my monitor
    goes red but i can see the Deskop. Its like looking to Desktop through
    RED filterglass. After 10min, RED colour is lost and monitor behaves
    normally. What happened to my monitors,guys? I know its hardware problem
    in my monitor. Tell me to what that problem is related to and how can i
    mend it.
    thank you
  2. #2
    Full Member level 1
    Points: 2,264, Level: 11
    tamerakshar's Avatar
    Join Date
    Jan 2006
    Posts
    97
    Points
    2,264
    Level
    11
    monitor goes red
    hi,
    did u check the cable.
    sometimes a wire loose can cause this.
    TeE ThE EdE
    •   Alt16th April 2006, 00:08
      advertising
  3. #3
    Full Member level 4
    Points: 3,366, Level: 13
    Join Date
    Nov 2001
    Posts
    239
    Points
    3,366
    Level
    13
    montor goes red
    Sounds to me that the red rive circuitry or the tube could be faulty. Be carfull if you decide to look at it yourself as there is a very high voltage generated at the final anode of the tube.
    Barrybear
  4. #4
    Advanced Member level 3
    Points: 6,562, Level: 19
    pisoiu's Avatar
    Join Date
    Dec 2002
    Romania
    Posts
    750
    Points
    6,562
    Level
    19
    computer monitor going red
    Go inside the monitor but be carefull at high voltages. In the most of the cases, you have a faulty contact on the video board or in the CRT connector, resolder the components. However, in very rare cases I've encountered situations when the heater made intermitent contact with the cathode. Check with an ohmmeter between the heater and the red cathode (with the video board removed and cold CRT). In this case you can try to discharge a capacitor between the shorted terminals of the heater and the cathode. It will either remove the fault, or it will completely destroy the heater, this is some sort of a last sollution. Don't blame me if you have to throw away your CRT after this operation (if it is the case, of course).
    /pisoiu
    •   Alt16th April 2006, 00:47
      advertising
  5. #5
    Member level 3
    Points: 1,533, Level: 8
    Join Date
    Jan 2006
    Posts
    54
    Points
    1,533
    Level
    8
    my monitor is lost red color how to fix
    butts 101,
    Guess u have some loose contact around the video section. re-sol;der whatever u find loose.
    luck,
    ras
    •   Alt17th April 2006, 02:20
      advertising
  6. #6
    Full Member level 3
    Join Date
    Apr 2005
    Posts
    168
    Points
    2,181
    Level
    10
    monitor going red
    hello there...
    i don't have to be too careful with high voltage since i'll be dissecting the monitor after unplugging the power or do i?
    And where is the most probable place that wire would be loose??
    thank you
  7. #7
    Full Member level 6
    Points: 6,204, Level: 18
    sawwa7's Avatar
    Join Date
    Oct 2004
    Posts
    331
    Points
    6,204
    Level
    18
    tyris monitor going red
    hi
    what's ur monitor's brand,model and chassis number?
    regards
  8. #8
    Full Member level 3
    Join Date
    Apr 2005
    Posts
    168
    Points
    2,181
    Level
    10
    monitor goes red what is the cause
    my monitor is daewoo 532x
    thank you
  9. #9
    Points: 9,214, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    859
    Points
    9,214
    Level
    22
    my computer screen goes red
    There are still high voltages inside the monitor after switching off, you have to wait till the capacitors discharge.
    Wait approx 10 mins and all should be fine.
    Try looking around the back of the tube, at the board there, where the video cable comes in through upto the board and all connections around it.
    Check also for other loose connections throughout the monitor.
    Does the usual method of temporary repair work? (bang it on the side - lol).
    •   Alt18th April 2006, 15:03
      advertising
  10. #10
    Full Member level 5
    Points: 3,856, Level: 14
    Join Date
    May 2002
    from istanbul in TURKEY
    Posts
    290
    Points
    3,856
    Level
    14
    my computer goes red
    look at capacitor of the video amplifier IC power suply
  11. #11
    Full Member level 3
    Join Date
    Apr 2005
    Posts
    168
    Points
    2,181
    Level
    10
    monior goes red
    My monitor is
    Daewoo 532X
    S.No. Gc07370258
    Chasis No 531X
    No success...
    I opened my monitor. I didn't see any loose connection that i needed to
    solder. There are many resistors, capacitors and diodes...is there any
    chance anyone of those being burn out? I just cleaned surfaces of CRT
    (black coloured dust) , blow the dust from the surface of devices.
    When i re-assemble and booted my computer...same problem...RED Monitor
    and after sometimes no more red coloured..monitor behaves normally.
    There is a big capacitor "C0824 220uF 400V" (is this a video amplifier
    power suppy IC) Is that problem related to that?
    Bang in the side of monitor doesn't work..but monitor flickers when doing
    that.
    thank you
  12. #12
    Newbie level 3
    Points: 1,335, Level: 8
    Join Date
    Apr 2006
    South Africa
    Posts
    Points
    1,335
    Level
    8
    monitor circuit diagram model 532x
    I have attached the electronic schematic diagram for this monitor:
    Daewoo 432X_523X.pdf
    Sheet 1: Power & Connection Section
    Sheet 2: Control & Vert.Out Section
    Sheet 3: Horizontal Section
    Sheet 4: Video Section
    This will enable you to trouble-shoot your monitor and resolve the problem with help from these fine poeple.
    Best Regards,
    Bernard
