wat's the purpose of having opto-coupler?
elmo_fei
Junior Member level 1
any1 plz tell me wats the usage of having opto-coupler in the drive circuit , then the output from opto-coupler connected to the gate of IGBT.......
10ssssssssss
A more deep explanation fo what IanP said.
It is necesary a isolation between high and low power
if a transitory or undesirable effect could use a low impedance path to flow and do damage. But if you use optocouplers that couldn't happen.
One example are Switching mode supplies.
www.fairchildsemi.com
on the menu
Design center
sub menu: Application block diagram
subsubmenu: power supply
