DRC problem in Cadence: failed to build VDB
payazal
Newbie level 1
drc problem in cadence
hello everyone,
i want to find a help for my problem, i design a logic gate using
cadence and when i made DRC using assura , i get message "failed to
build VDB, cannot summit DRC run" , i hope anybody can help me to solve
this problem, thanks
Re: drc problem in cadence
check your technology directory is at right location as mentioned in assura drc run form.
it is possible that you havenot started the license. and you check the file of .bashrc
i think the problem is when ever u run drc it will create a set of result files.
here the problem is u do not have permission to writre in to the disk where u invoked icfb.
so plz change the permission of the folder where u invoked icfb by chmod.
if u r not clear plz let me know
Check if any schematic instaces are present in layout. this is apart from the above.
hello,
it can may be a disk cota, check it ! or u have not a write permission change it with chmod commande from ur shell :
g@fsos
the rules mentioned for layout is a technology file or a directory?????
then whats the extension of technology file???
Look Assura Log file or message in CIW
Very "General" description of a Cadence problem.
Provide: Cadence version, Physical Verification tool version, Paste the .log file. Also CIW outputs. That would help..
Srivats
i m having error while i m running DRC.. error is can not build VDB file,failed DRC run... plz help me...plzzzzzzzzzz
#1:
Remove the .drc.Last.State file. If it is lvs, .lvs... or rcx is .rcx... and qrc is .qrc...
#2:
Sometimes, the variables are defined in the condition statement but never predefined in assignment statement.
