How to measure Er of unknown material by Network Analyzer?
myem
Full Member level 2
substrate measurement system ac microwave
when I got a unknown material , how do I measure Er by Network Analyzer ?
Any reference ???
THX
Re: measure Er
Among others technique the most common is using a
resonator. If you can cut or mould the material
would be easier. The most common resonator are
stripline, waveguide or just plain capacitor(put your
material betwwen two electrodes and measure the
resonance frequency)
Re: measure Er
What kind of resonator is the easiest for me to design?
Should I measure which parameter by VNA ?
Finally , how to calculate the Er ?
Any reference I can study ~
THX in advanced~
Re: measure Er
Dear myem,
1. search IEEE xplore for dielectric measurements - you get lots of different techniques including correction methods
2. If you are looking for a book, Microwave electronics (John Wiley) will tell you all about it.
3. **broken link removed**
Hope this is useful.
Regards,
Element7k
THX in advanced~
Re: measure Er
The Substrate Measurement System of AC Microwave is a specialized test fixture for use with a network analyer to measure permittivity and loss factor of planar dielectric samples. It applies the ring-resonator technique and uses electromagnetics-based post-processing. More info is available here: www.linmic.com/sms.htm
Andreas John
Re: measure Er
There are many method, suck like cavity pertubation, transmission line, and so on, you can find them in any microwave measurement cookbook
