How can I read analog values with dsPIC?
anksyete
Newbie level 5
hi,
how can I read analog values with dsPIC?
can anyone send a sample C code?
thanks...
dspic adc example
Example 17-5: Converting 4 Channels, Auto-Sample Start,
TAD Conversion Start, Simultaneous Sampling Code
ADPCFG = 0xFF78; // RB0,RB1,RB2 & RB7 = analog
ADCON1 = 0x00EC; // SIMSAM bit = 1 implies ...
// simultaneous sampling
// ASAM = 1 for auto sample after convert
// SSRC = 111 for 3Tad sample time
ADCHS = 0x0007; // Connect AN7 as CH0 input
ADCSSL = 0;
ADCON3 = 0x0302; // Auto Sampling 3 Tad, Tad = internal 2 Tcy
ADCON2 = 0x030C; // CHPS = 1x implies simultaneous ...
// sample CH0 to CH3
// SMPI = 0011 for interrupt after 4 converts
ADCON1bits.ADON = 1; // turn ADC ON
while (1) // repeat continuously
ADC16Ptr = &ADCBUF0; // initialize ADCBUF pointer
OutDataPtr = &OutData[0]; // point to first TXbuffer value
IFS0bits.ADIF = 0; // clear interrupt
while (IFS0bits.ADIF); // conversion done?
for (count = 0; count < 4; count++) // save the ADC values
ADCValue = *ADC16Ptr++;
LoadADC(ADCValue);
} // repeat
Added after 4 minutes:
You can see the "Section 17. 10-bit A/D Converter" from Microchip
