untel
Newbie level 1
802.16e data rate
Hi All,
I am trying to understand the requirements for an 802.16e Mobile WiMAX receiver with focus on the Mobile Station (MS)
1. How can I calculate the maximum data rate at a given MS (Mobile Station) with Mobile WiMAX (802.16e) using the current profile? (Profile: 10MHz bandwidth, TDD system, FFT=1024, 64QAM, frame length=5ms, etc.)
What is the maximum number of sub-channels that can be assigned to a single MS?
What would the maximum instantaneous data rate be at the MS receiver?
What is the maximum duration for which the maximum instantaneous bit rate needs to be supported?
What is the minimum idle time between two consecutive bursts at the CPE?
I would appreciate your input.
Regards, untel
Hi All,
Regards, untel
