what is the function of the PLL kick circuit?
tarkyss
Full Member level 6
China
who can explain it for me in detail or give me some links
thanks
I am not sure if it is relevant to your application but a PLL kick circuit is sometimes used in some servo systems to force swing through the capture range to achieve initial lock when the system has a very narrow operating capture and lock range.
One example is with the optical servo in a CD/DVD player where at switch-on the focus servo is kicked and forced to sweep through a large range to achieve initial focus lock.
    tarkyss
E-design
thank you very much, now i have another question
how to generate the kick signal?
tarkyss said:
E-design
you are right, the circuit is used in DVD read channel.
You confirmed by message that it is for a DVD read circuit.
There are various kick signals (they are normally applied while the servo is switched to open loop). One method for the focus search is in the form of a critically damped sinusoidal. This could be generated by a RLC circuit exited with a pulse. The moment focus is achieved (FOK), the loop is electronically closed again. This is sometimes called the focus search signal.
The other is a fixed current pulse applied to the tracking coil with the tracking servo in open loop during the pulse period. This is normally used for relatively short track jumps, such as for cue/review operations.
but what you said are analog circuits?
how can generate the kick signal in digital
I am only speculating on this. To generate the fixed pulse should be no problem. To generate the damped sinusoid you will need some kind of digital waveform generation where the shape is read out of memory and produced with a DAC. This is not my area of expertise, so maybe other members can help you on this side.
E-design, I see, you already helped me. thank you very much
