Can anybody tell me some good books about embedded system?
Thomson
Full Member level 3
Currently I'm designing an embedded SoC with several guys; however i'm not very familiar with embedded software development. Thereby i'd like to have good reommendations on books about this?
Thanks in advance!
Thomson
Re: Can anybody tell me some good books about embedded syste
You can search the e-book download section here for many useful books on embedded systems. You may want to specify a microcontroller to work with (8051, PIC, HC08, ....) and the language you intend to program with (Assembly, C, basic, ...).
Good luck
Good luck
Yes, you saied right!
I searched the e-book section before; however there're a lot of books about embedded software development about various MCU and i have no idea which ones are better suited for my current project.
I'm now implementing such a system with 8051 and C.
Can you give me some suggestions?
Thansk in advance.
hi thomson
see these links,might be helpful for 8051.
h**p://www.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=209&PageID=215&gid=9&fid=10&category=All&showall=false
h**p://www.microchip.com/ParamChartSearch/chart.aspx?branchID=111&mid=10&lang=en&pageId=74
One of the best is "the final word on the 8051".
You can download it and many other useful things here:
h**p://www.8052.it/download.htm
see the following links
h**p://ezshare.de/files-en/171087/p8051arc.pdf.html
h**p://ezshare.de/files-en/171091/p8051ds.pdf.html
h**p://ezshare.de/files-en/171098/p8051hw.pdf.html
h**p://ezshare.de/files-en/171103/p8051pg.pdf.html
h**p://ezshare.de/files-en/171107/pan457.pdf.html
h**p://ezshare.de/files-en/171111/dallasnoisealeapp91.pdf.html
h**p://ezshare.de/files-en/171119/application-notes.pdf.html
these are from intel's site:
h**p://www.intel.com/design/mcs51/manuals/272383.htm
h**p://www.intel.com/intelpress/usb/examples/asoverview.htm
h**p://www.intel.com/design/mcs51/datashts/27262002.pdf
h**p://www.intel.com/design/auto/mcs96/applnots/23065901.pdf
Try reading "Embedded System Design on a Shoestring"
www.scienceprog.com
hai,
for begineers i think u should be good enough with 8051 microcontroller
i will strongly recommend 'the 8051 microcontroller and embedded systems' by mazidi and mazidi.
there is a pdf file u can search and download it , it is called"8051 final word"
if u can not reach it i will send it to u if u need.
