+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 2
    Points: 2,451, Level: 11
    Join Date
    Sep 2005
    Posts
    49
    Points
    2,451
    Level
    11
    verilog fread
    hi all,
    how to assign the input data written in a file to the port, for testbench purpose using verilog hdl?
    suppose i have some samples of input data written in .dat file,
    and in my testbench i want to input all the values written in that file, how can i do it?
    i have tried in the below manner and could not find any data assigned to the input pin while simulating,
    data_in = $fopen('' input.dat","r");
    please help to solve this.........
    •   Alt10th March 2006, 10:25
      advertising
  2. #2
    Member level 4
    Points: 1,779, Level: 9
    Join Date
    May 2005
    Posts
    69
    Points
    1,779
    Level
    9
    verilog read file
    $fopen will only open the file. To do any file operation in verilog this has to be done first. for reading from file try $memreadb (for binary files) or $memreadh (for hex files).
    eg :
    reg [7:0] mem[1027:0];
    initial
    begin
      $readmemb("file_name",mem);
    end
    U also have $fscanf, $fgetc, $fread to read files. Not sure abt the exact syntax for their usage, but should be similar to above one.
    1 members found this post helpful.
  3. #3
    Full Member level 2
    Points: 2,031, Level: 10
    Join Date
    Mar 2005
    Posts
    129
    Points
    2,031
    Level
    10
    verilog read from file
    system command
    •   Alt10th March 2006, 12:33
      advertising
  4. #4
    Advanced Member level 3
    Points: 9,269, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,269
    Level
    23
    verilog file read
    Here is the example ur looking for .....
    Hope this helps
    module stim_gen (
       // Outputs
       clk, data
       output clk;
       output [7:0] data;
       reg    clk;
       reg [7:0] data;
       integer   fd;
       integer   code, dummy;
       reg [8*10:1] str;
       initial begin
          fd = $fopen("_input.dat","r");
          clk = 0;
          data = 0;
          code = 1;
          $monitor("data = %x", data);
          while (code) begin
             code = $fgets(str, fd);
             dummy = $sscanf(str, "%x", data);
             @(posedge clk);
          end
          $finish;
       end // initial begin
       always #5 clk = ~clk;
    endmodule // stim_gen
    Contents of _input.dat file
    2 members found this post helpful.
  5. #5
    Advanced Member level 2
    Points: 7,314, Level: 20
    Join Date
    Dec 2005
    Posts
    651
    Points
    7,314
    Level
    20
    reading a file in verilog
    FYI,
    If you want to process binary data, this can be tricky readmemb did not work for me when I needed to do this. I finally ended up using:
    file = $fopen("code.vec", "r");
    return_value = $fread( mem, file);
    if (return_value !=1)
    error = 1;
    else
    "mem" is an eight bit varible. When the return_value is not 1, then the read failed and you are at the end of the file.
    --- Steve
    •   Alt10th March 2006, 13:58
      advertising
  6. #6
    Member level 3
    Points: 1,112, Level: 7
    Join Date
    Mar 2010
    Pakistan
    Posts
    60
    Points
    1,112
    Level
    7
    Re: verilog file read
    thanks for the example code nand gates....however i tried it and gave me errors so i tried making changes. Firstly for me an 'always' worked before the @(posedge clk) statement. Even after making this change it keeps giving me errors. Can someone please help me debug?
  7. #7
    Newbie level 2
    Points: 201, Level: 2
    Join Date
    Nov 2011
    Posts
    Points
    201
    Level
    Re: reading a file in testbench(verilog)
    Hi all if any body implemented dwt image processing using verilog can u just send me the architecture and fsm design(if possible) or tell me how to start the coding part.please help me in that.
