+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 2
    Points: 3,120, Level: 13
    Join Date
    May 2004
    Posts
    144
    Points
    3,120
    Level
    13
    What is the difference between Nmos and Pmos?
    •   Alt9th March 2006, 05:23
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: What is the difference between Nmos and Pmos?
    NMOS and PMOS
    In NMOS transistors, the silicon channel between the source and drain is of p-type silicon. When a positive voltage is placed on the gate electrode, it repulses the holes in the p-type material forming a conducting (pseudo n-type) channel and turning the transistor on. A negative voltage turns the transistor off. With a PMOS transistor, the opposite occurs. A positive voltage on the gate turns the transistor off, and a negative voltage turns it on. NMOS transistors switch faster than PMOS.
    http://www.answers.com/topic/mosfet
    Regards,
    IanP
    1 members found this post helpful.
