+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Full Member level 1
    Points: 3,298, Level: 13
    Kryptonite's Avatar
    Join Date
    Feb 2006
    AUH, UAE
    Posts
    105
    Points
    3,298
    Level
    13
    WHY 50/60 Hz????????
    Hello,
    i have 2 questions that may hit anyone's mind working in the field,
    1- Why Northa America uses 60 Hz as operating frequency in power systems & electric machines & residental appliances while the rest of the world uses 50 Hz??
    2- Consider the well known 50 or 60 Hz to be the same,, Why not using 100, 150 or 200 for that matter?????
    Your answers r highly appreciated
    Best Regards & Thx........
  2. #2
    Super Moderator
    Points: 15,579, Level: 30
    E-design's Avatar
    Join Date
    Jun 2002
    Posts
    1,964
    Points
    15,579
    Level
    30
    Re: WHY 50/60 Hz????????
    I can't answer the 50/60Hz point, but using AC becomes a problem over very long distances because of reactances. Capacitance in AC power lines limits the distance over which power can be carried. You may be surprised to know that for very long distances DC is preferred (and actually implemented in various part of the world like Canada)! The advances in electronic inverters makes this very easy these days. Raising the frequency above 60Hz will make the reactance problem much worse.
    •   Alt4th March 2006, 18:49
      advertising
  3. #3
    Advanced Member level 2
    Points: 6,625, Level: 19
    v_c's Avatar
    Join Date
    Oct 2005
    Chicago, IL, USA
    Posts
    514
    Points
    6,625
    Level
    19
    Blog Entries
    This link is very informative -- I think it should answer most of your questions.
    http://www.school-for-champions.com/..._volt_freq.htm
    •   Alt4th March 2006, 19:04
      advertising
  4. #4
    Full Member level 1
    Points: 2,264, Level: 11
    tamerakshar's Avatar
    Join Date
    Jan 2006
    Posts
    97
    Points
    2,264
    Level
    11
    Nikola Tesla calculated that frequency,but why 50-60 Hz?
    for higher frequencies the inductance (2ΠfL) will increase dramatically,increasing the impedance which leads to power line loss.
    Freqquency also effects machines & generators at thier speeds voltages.
    50 to 60 Hz is the effictive range.
    TeE ThE EdE.
    Added after 4 minutes:
    I think this is an industrial policy.
    TeE ThE EdE.
    •   Alt4th March 2006, 20:21
      advertising
  5. #5
    v_c's Avatar
    Join Date
    Oct 2005
    Chicago, IL, USA
    Posts
    514
    Points
    6,625
    Level
    19
    Blog Entries
    It is interesting to note that the wavelength of a 60Hz wave is 5000 km which is roughly 3000 miles and this is approximately the the distance coast to coast (Atlantic to Pacific) of the United States.
  6. #6
    Super Moderator
    E-design's Avatar
    Join Date
    Jun 2002
    Posts
    1,964
    Points
    15,579
    Level
    30
    Bulk DC power transmission will be one of the topics for the next international conference of AC & DC power transmission.
    http://conferences.iee.org/acdc/wednesday.htm
  7. #7
    Member level 1
    Points: 1,488, Level: 8
    Join Date
    May 2005
    Posts
    33
    Points
    1,488
    Level
    8
    i suspect the frequency has something to do with the way of the generator working. also, 60/50 look pretty arbitrary, actually in Japan there are both 60/50 systems/areas
    Quote Originally Posted by Kryptonite
    Hello,
  8. #8
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    i think its 60Hz for reasons of calculation
    60 X 6 = 360 so its easy to do phase calculations in base 10 using 60 hz fundimental
    look here for many different grids
    http://www.worldgrid.net/
    a good software for research into grid systems
    you see its quite simple
    the TV
    tv runs at 60hz needs 60 frames per second
    so the picture isnt dull if you use fast switching lights
    eyes run at 25 - 30Hz frame rate
    who knows???
    i think its all a matter of exactly what voltage you transport
    forinstance in 60Hz zone
    you usualy find main distribution pilons is 1 million volts
    for 50hz this is a lower voltage around 750,000
    as the wire is a certain thickness and purity
    its all calculated for max transfer of energy and less heat etc etc
    just differtent approch... i beleve in japan there is a 110 100hz supply for goverment purposes
    maybe metric and imperial systems ... as
    1" = 1 second of arc = 1 second of time in imperial systems
    not the same in cm's
  9. #9
    Points: 1,938, Level: 10
    Join Date
    Jul 2002
    Cordoba Argentina
    Posts
    Points
    1,938
    Level
    10
    I don't know the reason about why 50 or 60, but take care of the 50/60Hz switch on the table clocks. They usually takes the zero crossing of the line signal to move its internal counter and keep the pace, so, if you feed with 60Hz a clock inteded for 50Hz, it will not blow off but will be out of time (advanced)...
  10. #10
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    Kryptonite,
    In the interest of further muddying the water, the standard frequency for aircraft power is 400 Hz. The higher frequency is preferable because it allows less iron to be used in magnetic components, thus reducing weight.
    Regards,
    Kral
    •   Alt7th March 2006, 00:12
      advertising
  11. #11
    Member level 3
    Points: 2,012, Level: 10
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    St. Petersburg, Florida
    Posts
    56
    Points
    2,012
    Level
    10
    One more interesting note:
    TV's used 60Hz refresh rate because of the lack of good filters and shielding back 60 years ago. If locked to the power line freq., the effect of the hum is stationary and less noticable.
    When color came out, the refresh rate, now being related to the color carrier is actually 59.9999, which is why, when you lose a power supply filter now the "hum bar" in the picture moves up the screen slowly.
    Someone correct me if I'm wrong, but I believe the PAL standard is locked to 50Hz for Europe.
  12. #12
    Member level 2
    Points: 1,616, Level: 9
    Join Date
    Sep 2004
    Posts
    49
    Points
    1,616
    Level
    9
    Generally, Transformers of 60Hz are smaller in size with respect to those of 50Hz, when they have the same capacity; On the other hand, current in the 50Hz system has less reactance than that in the 60Hz system.
