+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Points: 1,514, Level: 8
    Join Date
    Nov 2005
    Posts
    7
    Points
    1,514
    Level
    8
    turbo codes
    I want to start working on turbo codes. I have read and heard alot about it. I want to discuss these questions :
    1- which software is more proper to simulate complete channel coding aspects based on umts standard? some say matlab is too low speed for this purpose. what about programing in c ?
    2-i do not know much about c programing. is it possible to write c codes of simulation turbo codes in 3 or 4 mounth? where can I find some good code sources which can help me.
    3-is it possible to implement this channel coding standard (umts) using DSK boards. I need to know what are the exact equipments needed.
    I will appriciate any idea from you.
    thanks
    •   Alt23rd February 2006, 13:23
      advertising
  2. #2
    Advanced Member level 1
    Points: 5,140, Level: 16
    Join Date
    Jun 2004
    india
    Posts
    487
    Points
    5,140
    Level
    16
    turbo codes
    from my experience matlab is efficient and all peoples will accept if u do in MATLAB only.
    all other coding wont give effective channel effiency.
    •   Alt24th February 2006, 04:27
      advertising
  3. #3
    Newbie level 1
    Points: 1,346, Level: 8
    Join Date
    Mar 2006
    Posts
    Points
    1,346
    Level
    8
    turbo codes
    Hi its good to implement Turbo codes in C... ya matalab simulation takes really huge time... to plot ebno curve upto a ber 10 e -5 in matlab it takes nearly 1 or 1.5 days but in c it took hardly 30 minutes.... yes u can implement within 2 months if u work properly....
    •   Alt11th March 2006, 06:24
      advertising
  4. #4
    Member level 3
    Points: 1,829, Level: 9
    Join Date
    Sep 2004
    Posts
    67
    Points
    1,829
    Level
    9
    turbo codes
    sorry for this question, but i need to know
    if i want to simulate a simple example on a channel coding (turbo coding) using matlab, is going to take as long as you mentioned before, or is it because it
    is a complete simulation of a Umts standard??
    Regards
    The Sniper (+)
  5. #5
    Full Member level 5
    Points: 2,897, Level: 12
    Join Date
    Nov 2004
    Posts
    273
    Points
    2,897
    Level
    12
    Re: turbo codes
    I will say, if you are working on error correcting code research, pls go for C language. If you are more keen on implementation (or just to complete school project), I will say MATLAB is the best. I have my turbo code in both matlab and c language.As mentioned, the speed is really fast for C language. But, for the sake of convenience, I will say Matlab is the best. Since you need to complete within 2-3 months,I will suggested you to do it by using matlab.
    There are quite alots of well developed turbo code written in MATLAB. For me, I am using this turbo code for my research.
    http://www.ee.vt.edu/~yufei/turbo.html
    This matlab code is well written and 100% correct. Hope you can make use of it.
