+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 5
    Points: 1,356, Level: 8
    Join Date
    Sep 2005
    Posts
    9
    Points
    1,356
    Level
    8
    set_clock_gating_check
    hi,
    How to decide what value shoud I put for set_clock_gating_check setup & hold time? Frequency for my design is 80Mhz
    •   Alt21st February 2006, 04:57
      advertising
  2. #2
    Full Member level 5
    Points: 2,750, Level: 12
    Join Date
    Apr 2005
    china
    Posts
    258
    Points
    2,750
    Level
    12
    set_clock_gating_check -high
    maybe decided by your gated clock cell!!
    •   Alt21st February 2006, 05:31
      advertising
  3. #3
    Full Member level 2
    Points: 2,115, Level: 10
    Join Date
    Apr 2005
    Shanghai, China
    Posts
    141
    Points
    2,115
    Level
    10
    set_clock_gating_check is set on the AND cell, which provided gated clock output.
    it garantee the clock should arrive earlier than the gating signal, and its value is decided by the input pin relation of the AND cell that you selected.
    generally, it is just an additional check, if you put the LATCH and AND cell close enough, then it is just no need to set.
    1 members found this post helpful.
    •   Alt23rd February 2006, 15:04
      advertising
  4. #4
    Full Member level 1
    Points: 3,056, Level: 13
    Join Date
    Jun 2003
    Posts
    112
    Points
    3,056
    Level
    13
    if u have gated clocks in the design, then it is best to use set_clock_gating_check. Otherwise u may end up in surprises while testing
  5. #5
    Newbie level 6
    Points: 1,306, Level: 8
    Join Date
    Feb 2006
    Posts
    12
    Points
    1,306
    Level
    8
    may be this article will help u,"How To Successfully Use Gated Clocking in an ASIC design ,Darren Jones ,SNUG Boston 2002".
    enjory it.
    regards
  6. #6
    Full Member level 5
    Points: 6,241, Level: 18
    roli's Avatar
    Join Date
    Apr 2001
    'SiliconWafer' Island
    Posts
    246
    Points
    6,241
    Level
    18
    Re: set_clock_gating_check
    Quote Originally Posted by free1983
    enjory it.
    regards
    Here it is:
    http://www.edaboard.com/viewtopic.ph...t=darren+jones
    •   Alt2nd August 2007, 06:34
      advertising
  7. #7
    Full Member level 2
    Points: 1,852, Level: 10
    Join Date
    Jul 2007
    bangalore
    Posts
    132
    Points
    1,852
    Level
    10
    clock gating using the reduecd power consumtion .
    clock gating means stop working of the clock.but that FF value doesnot changed
    vamsi
