+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 4
    Points: 2,433, Level: 11
    Join Date
    Dec 2004
    Posts
    230
    Points
    2,433
    Level
    11
    op07 load cell
    What are the main difference between LM741 and OA07 Op-Amp. And is there any specific application of OA07. Please give some info.
  2. #2
    Full Member level 1
    Points: 1,796, Level: 9
    Join Date
    Aug 2005
    Posts
    99
    Points
    1,796
    Level
    9
    lm741
    Did you mean OP07? If so the OP07 is a precision opamp with very low offset voltage and current and low voltage noise meant for DC and low frequency "instrumentation" applications requiring large gain while the LM741 is one of the first opamps on the market outdated now and has relatively rarge offset voltage and current. There are much better low cost opamps on the market than the LM741 and even better than the OP07.
    •   Alt20th February 2006, 16:38
      advertising
  3. #3
    Advanced Member level 2
    Points: 6,625, Level: 19
    v_c's Avatar
    Join Date
    Oct 2005
    Chicago, IL, USA
    Posts
    514
    Points
    6,625
    Level
    19
    Blog Entries
    datasheet lm741 texas
    Datasheet for the OP07 is here http://www.analog.com/en/prod/0,,759_786_OP07,00.html
    The datasheet says that the OP07 has applications in
    • Wireless Base Station Control Circuits
      Optical Network Control Circuits
      Instrumentation
      Sensors and Controls
      Thermocouples
      RTDs
      Strain Bridges
      Shunt Current Measurements
      Precision Filters
    I agree with ptmsl that LM741 is pretty outdated -- you can easily find better opamps. Just visit National Semiconductor's website http://www.national.com for example. Use the 741 if you have nothing else available to you.
    •   Alt20th February 2006, 19:23
      advertising
  4. #4
    Member level 4
    Points: 2,358, Level: 11
    Join Date
    Aug 2005
    Posts
    78
    Points
    2,358
    Level
    11
    current shunt lm741
    is lf347 quiet good than OP07 (i know it's QUAD op-amp but i'm asking performance type, against op07)????
    •   Alt20th February 2006, 20:19
      advertising
  5. #5
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    230
    Points
    2,433
    Level
    11
    lm741 current shunt
    Thanks for your help guys. Yes I mean OP07 NOT OA07 by mistake I typed OA07. Which is the best Op Amp for amplifying load cells output. Any suggestio.
  6. #6
    Full Member level 1
    Join Date
    Aug 2005
    Posts
    99
    Points
    1,796
    Level
    9
    lm741 open loop gain
    For load cells you will need an opamp with good DC characteristics like the OP07 (even better the OP77) and not a general purpose old design like the 741. Also you dont need a fet input opamp like the LF347 unless your load cell has a very large output resistance (in the Megohm range) but I think load cells have small output resistances around 1K. Any good low offset voltage - large DC open loop gain opamp can work. Most companies like Analog devices, National semiconductors, Linear technologies, Texas etc. have selection guides that will help you decide which is the best opamp for your application. Since you need to amplify a voltage in the millivolt range coming from a low resistance source, input offset voltage offset voltage stability and noise voltage at low frequencies are important to you. Opamps for use as instrumenttion amplifiers are most suitable.
    The LF347 is better for AC applications because of the higher slew rate and Gain Bandwidth and for applications with high source resistance because of its low input current but like most FET input opamps its offset voltage is worse and it has less open loop large signal voltage gain. So for low offset DC applications OP07 is much better.
  7. #7
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    230
    Points
    2,433
    Level
    11
    op amp op 07 lm741
    Thanks ptmsl for info. I will try OP77 Op-Amp in my design. Thanks again. You have any ebook on Op-Amp design.
  8. #8
    Full Member level 1
    Join Date
    Aug 2005
    Posts
    99
    Points
    1,796
    Level
    9
    1 members found this post helpful.
    •   Alt21st February 2006, 10:30
      advertising
  9. #9
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    230
    Points
    2,433
    Level
    11
    op07 opamp application
    Thanks ptmsl a lot for such a nice bible for Op-Amp. It shoes lot of for Op-Amp. I want to download ebooks from edaboard but it requires more points to download. Can you donate me your points so I will download.
