+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 3
    Points: 7,794, Level: 21
    Join Date
    Sep 2004
    Bangalore,India
    Posts
    804
    Points
    7,794
    Level
    21
    Active & Passive Elements
    What is meant by Active & Passive elements?.... How they differ?....
  2. #2
    Full Member level 3
    Points: 2,787, Level: 12
    eecs4ever's Avatar
    Join Date
    Jan 2006
    Analog Environment
    Posts
    179
    Points
    2,787
    Level
    12
    http://en.wikibooks.org/wiki/Circuit...ssive_Elements
    "The elements within a circuit will either control the flow of electric energy or respond to it. Those elements which control the flow of electric energy are known as active elements and those which dissipate or store the electric energy are passive elements."
    "The three linear passive elements are the Resistor, the Capacitor and the Inductor. Examples of non-linear passive devices would be diodes, switches and spark gaps. Examples of active devices are Transistors, Triacs, Varistors, Vacuum Tubes, relays, solenoids and piezo electric devices."
    If I were a semiconductor device, I'd want to be an active element =]
    •   Alt7th February 2006, 09:39
      advertising
  3. #3
    Full Member level 3
    Points: 2,982, Level: 12
    Join Date
    Feb 2004
    Bangalore, India
    Posts
    184
    Points
    2,982
    Level
    12
    Re: Active & Passive Elements
    Active elements are those which does not depend on other elements for operation eg.Transistors etc.
    Passive elements are those which depends on others for elements
    eg.Resistors, capacitors, inductors
    •   Alt7th February 2006, 12:51
      advertising
  4. #4
    Full Member level 5
    Points: 4,127, Level: 15
    neils_arm_strong's Avatar
    Join Date
    Jan 2006
    Posts
    288
    Points
    4,127
    Level
    15
    Active elements supply energy or control the flow of energy.
    Passive elements dissipiate energy.
    Ex: Voltage sourcees,transistors etc are active elements
    Resistors and other linear elements like capacitor,inductor or any appliance is a passive element
    •   Alt8th February 2006, 13:39
      advertising
  5. #5
    Advanced Member level 2
    Points: 5,970, Level: 18
    Join Date
    Nov 2004
    Tamilnadu
    Posts
    657
    Points
    5,970
    Level
    18
    Quote Originally Posted by kumar_eee
    deviec which can amplify ---active element eg BJT,FET,OPAMP
    device which cannot amplify --passive element eg PN diode,resistor,L ,C
    list is endless...
    [color=#999999]
    color]
    [quote="eecs4ever"]
    Added after 13 minutes:
    Quote Originally Posted by eecs4ever
    h**p://en.wikibooks.org/wiki/Circuit_Theory:Active_vs._Passive_Elements
    really relays and solenoids are active devices...how it is eecs4ever.....
    1 members found this post helpful.
  6. #6
    Points: 7,347, Level: 20
    the_risk_master's Avatar
    Join Date
    Aug 2005
    UE+MIT, Philippines, (14N , 120E )
    Posts
    662
    Points
    7,347
    Level
    20
    passive components--
    A device that does not have any impact on the electrical signals or the data that passes through it. See active component.
    Examples of passive components include resistors, capacitors, inductors, and diodes. The classic crystal radio receiver, an AM radio receiver that does not require any electricity, is made entirely from passive components.
    active component--
    A device that adds intelligence in some manner to the signal or data that passes through it. For example, in networking, an active hub regenerates fading input pulses into new, strong output pulses. In contrast, a passive hub is just a junction box that does not affect the passing data.
    Examples of active components are transistors, thyristors, diodes and valves.
    Note: the diode can be a passive or active component.
  7. #7
    Points: 1,249, Level: 7
    Join Date
    Feb 2006
    Mumbai
    Posts
    Points
    1,249
    Level
    7
    Active devices are sources of energy, converting between forms of energy: chemical, hydraulic, thermal energy, mechanical , nuclear, solar, etc, into electrical energy, driving electrical current around the circuit and hence delivering continuous energy to it. An active component is one that has gain or depends on the direction of the current
    All electrical devices which consume rather than produce energy are called passive devices, like resistors, inductors and capacitors. A passive component is an electronic component that does not require a source of energy to perform its intended function. Examples of passive components include resistors, capacitors, inductors, and diodes. The classic crystal radio receiver, an AM radio receiver that does not require any electricity, is made entirely from passive components
    •   Alt11th February 2006, 14:13
      advertising
  8. #8
    Join Date
    Nov 2004
    Tamilnadu
    Posts
    657
    Points
    5,970
    Level
    18
    Quote Originally Posted by soniya_ahuja
    is there any proof exists for your say that AM radio receiver don't any power to work......
  9. #9
    Full Member level 4
    Points: 4,144, Level: 15
    Join Date
    Nov 2004
    USA
    Posts
    211
    Points
    4,144
    Level
    15
    A crystal radio is entirely passive (a coil type antenna, a capacitor, a diode, and a speaker). The power for the radio actually comes from the AM radio signal itself. The coil converts the radio signal into a voltage signal. The coil and the capacitor tune the circuit to the right channel. The diode demodulates the signal and the speaker makes it audible. No batteries required or power supply required.
