REQ: Programmer adapter board schematics for pic micro's
The Puma
Full Member level 2
the board must program a 16f84a/16f876/16f877 through a isp connector
attached you'll find a schematic for the P16Pro-PIC-programmer. Around the ZIF-socket you can see the different connections/bridges to use various PIC-types. The whole program can be downloaded from www.picallw.com, but the schematic is included in the old DOS-part only. In case of doubt consider the datasheets; the necessary pins to program a PIC are Vcc, Gnd, MCLR, RB6 and RB7 (for 'normal' , no low-voltage programming).
Mik
I post these two, fully tested:
Check this site...
w*w.ic-prog.com/index1.htm
Both schematics and a good freeware programmer software
/J
