How to use the 555 timer to delay an incoming signal for a specific amount of time?
hadef
Newbie level 3
how could i use the 555 timer to delay the coming signal for specific amoint of time
i mean i need a circuit that will alarm 2 minutes after the darkness is detected
Re: timer 555
Connect one 555 as 2-minute delay timer and another 555 as the alarm timer ..
The first timer is triggered by a photo-resistor (dark detector), the second timer is trigged by the first timer (alarm timer) ..
Examples of both circuits can be copied from:
Regards,
IanP
Re: timer 555
it could help you :
Re: timer 555
u need a monostable circuit so 555 timer is nice select for this
this circuit is adjustable 0sec to 8minute
Re: timer 555
for this you have to connect it with the ldr tha a delay circuit and then a 555 timer it will gives you more accurate idea how the circuit hsould work
Re: timer 555
Convert 555 into monostable multivibrator..that will act as a delay circuit
