How to properly do AC open loop LDO simulation?
jutek
Full Member level 4
hello
could you tell me how to do AC open loop LDO simulation properly?
how the inputs should be polarized when i open the loop to pass device give me the current i want to
when i do transient and op analyses, everything is ok. vref is connected to - and output voltage through feedback divider to +.
i want the AC simulation to be adequate TRANSIENT simulation, to be sure how gain, UGF and pole/zero position influence transient response
thanks in advance
regards
ldo ac simulation
jutek said:
hello
thanks in advance
regards
Hi ,
In the attached pdf go to AC analysis ( page 17, Chapter 2). It clearly explains where the loop must be broken in order to do ac analysis.
  • ldo_book_140.pdf
ac response ldo
hello
yes, i have this book, and i exactly break the loop in this place. but what should be connected to - after breaking? if i use only AC=0.1 and no DC value the result is not good cause opamp is not polarized well
ldo simulation setup to characterize the design
jutek said:
hello
Add large R&C in your feedback path,you can build up the DC point and break the AC feedback path.
Reactions: #oz
    #oz
ldo ac analysis
add a dc offset voltage at the input pin,
exmple:vin in 0 dc 1.25 ac 1
break loop pole/zero hspice
Yes, remerber to add a dc voltage.
The dc voltage would make the DC operation point accurate.
in hspice there is a resistance that when dc the value is zero, but when ac, it is open. Can we just use the thing?
ldo current profiles
add a ac resister(dc=0.001Ohm, ac=1000,000kOhm) between the two break point;
feed ac signal in though a 1F capacitor;
Added after 8 minutes:
also, please aware the loading on the open loop output point,
it should have the same loading with which in close loop.
ac analysis of ldo
I also confused it, sometimes, I use the AC source with ac=1V to break the loop.
sometime, I use the resistor with AC=1G , and a cap=1F . and sometime, I use
the ind=1G and a cap =1F.
the only diff thing I thought is the phase of it different. But offten, the gain plot is
also diff.
So, I use the method mostly equal what I think it should be.
how to do ac analysis of ldo
another way is add a large inductor on you feedback path, and a capacitor connect to ground from opamp side. this may help you to do AC simulation.
ac anslysis of ldo
this maybe a good idea!
but it could make some other problem. when I connect a capacitor (c=10p) parallelled with resistor R3, it should bring a pole and a zero. But because the large capacitor(c=1KF) connected in the input so by hspice simulation the capacitor parallelled with the resistor R3 will not take some effect!
ads simulation ldo
another way is to use two LDOs , one closed loop and the other is open loop , then use the closed loop LDO to get the DC for the open loop LDO.
ldo simulations
1/(C_OL*L_OL)^0.5 must be less than simulation min. frequency.
ldo openloop simulation
hi mark_nctu!
Why 1/(C_OL*L_OL)^0.5 must be less than simulation min. freq? Can you explain it for me?
Thanks.
ldo spice simulation
Can I use the resistor instead of the inductor for AC simulation.
coolroyy
pls check the ac response in the VDIV
Added after 1 minutes:
Yes,but the res must very large
LDO AC simulaton
You can break the loop using L (1G) and C(1F) values. AC signal can pass through the capacitor and inductor allows DC value and breaks the loop
Re: LDO AC simulaton
Please find the attach document for more clarification
  • f4_3269.pdf
    V
LDO AC simulaton
really good one,i just need this,support!
i would like to ask how to get this book by free of charge
