+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
  1. #1
    Junior Member level 3
    Points: 1,496, Level: 8
    Join Date
    Jan 2006
    Posts
    31
    Points
    1,496
    Level
    8
    at89c51 projects
    I'm learning to write code for AT89C51 microcontroller. I have this habit of learning by examples. Can someone please help me get some complete projects as to how to wire up the hardware and write code for the uController in a step by step manner? Please Help.
  2. #2
    Full Member level 4
    Points: 2,433, Level: 11
    Join Date
    Dec 2004
    Posts
    230
    Points
    2,433
    Level
    11
    at89c51
    By doing experiments on 89C51 you will learn soon. I suggest you to code for DTMF decoder. Use LCD module for this.
    1 members found this post helpful.
  3. #3
    Full Member level 2
    Points: 2,058, Level: 10
    Join Date
    Oct 2004
    Posts
    135
    Points
    2,058
    Level
    10
    at89c51 based projects
    For the first time i'd suggest:
    1. switch the led to on/of (better use 8 led so you can use each pin in 1 port) using your microcontroller
    2. use the interrupt to control the led (the led will run automaticly)
    3. use timer to control the speed of your led
    4. try using LCD (there's a nice tutorial at http://www.8052.com)
    That's it about the i/o. Most of my project using I/O so i decided to make a good basic, after that you can try the serial and maybe some motor using PWM
    •   Alt27th January 2006, 16:52
      advertising
  4. #4
    Join Date
    Jan 2006
    Posts
    31
    Points
    1,496
    Level
    8
    at89c51 microcontroller projects
    Can you please guide me in this regard please? I don't know where to start and where to start... Please Help...
    Added after 4 minutes:
    I mean... is there any site where you are taught how to write code for real time projects... that is...why you are writing that line or explain the problem first in an algorithmic fashion and then solve the problem...
  5. #5
    Full Member level 2
    Join Date
    Oct 2004
    Posts
    135
    Points
    2,058
    Level
    10
    projects using at89c51
    First maybe you need the tutorial....
    Go to http://www.8052.com there's a good tutorial how to coding there.
    I suggest you to use AT89S52 that include timer2 and ISP so you can program it easily using serial/parallel port.
    There's a lot of schematics and program to burn your mcs. Currently i'm using this:
    http://www.aec-electronics.co.nz/software.htm
    Happy learning, hope this help you
    Best Regards
  6. #6
    Member level 2
    Points: 1,963, Level: 10
    Join Date
    Oct 2005
    Posts
    42
    Points
    1,963
    Level
    10
    microcontroller at89c51 projects
    The book 8051 by Mazidi is a good resource you can find many practical examples with complete description in it.
  7. #7
    Full Member level 4
    Points: 3,002, Level: 12
    eng_ahmed22's Avatar
    Join Date
    Jun 2005
    Posts
    190
    Points
    3,002
    Level
    12
    at89c51
    hi ALL
    i strongly recommend a book called: Embedded C by Michael J. Pont
    it is so easy and suitable for beginners specialy who have a little experience in c programming. it fulled by examples.( from turn on led to creat your own operating system)
    it use the 8051 c and the ke*il software.
    it is great for beginners.
    here is its link:
    http://www.edaboard.com/viewtopic.ph...ght=embedded+c
    hope u enjoy with c world.
    good luck
    bye
    Ahmed
    •   Alt30th January 2006, 12:37
      advertising
  8. #8
    Full Member level 1
    Points: 2,038, Level: 10
    Join Date
    Apr 2005
    Posts
    110
    Points
    2,038
    Level
    10
    digital clock using at89c51
    hey dude just read majidi and majidi
    youll be doing fine
  9. #9
    Advanced Member level 2
    Points: 4,896, Level: 16
    UroBoros's Avatar
    Join Date
    May 2004
    Cochin - India
    Posts
    633
    Points
    4,896
    Level
    16
    at89c51 rgb pwm
    Hai
    look for "8051 bible" in this board
    picstudent
  10. #10
    Points: 1,426, Level: 8
    Join Date
    Mar 2005
    Posts
    Points
    1,426
    Level
    8
    code at89c51
    view my web you will find son intresting AT89C51 complete projects on www.geocities.com/syedpervez/8051.html
    syed Pervez Ali
    •   Alt31st January 2006, 08:42
      advertising
  11. #11
    Junior Member level 2
    Points: 1,833, Level: 9
    Join Date
    Jun 2005
    Posts
    20
    Points
    1,833
    Level
    9
  12. #12
    Full Member level 3
    Points: 6,362, Level: 19
    Join Date
    Jan 2000
    Posts
    163
    Points
    6,362
    Level
    19
    sdcc at89c51
    This site has simple projects and tutorials:
    http://www.iguanalabs.com/
  13. #13
    Advanced Member level 3
    Points: 7,169, Level: 20
    Join Date
    Jan 2006
    Bangalore India
    Posts
    805
    Points
    7,169
    Level
    20
    Blog Entries
    at89c51
    the book from which i have learned is "the 8051 microcontroller by kenneth j ayala.
    I would like to suggest u to learn things in C or basic rather then asm, but first start with asm that ill give u good hold. for C u can use keil, sdcc, etc
  14. #14
    Join Date
    Mar 2005
    Posts
    Points
    1,426
    Level
    8
    projects on at89c51
    View this WEB site it will help u.
    http://www.kmitl.ac.th/~kswichit/
    also view my web for some MCS-51 Ready project
  15. #15
    Newbie level 2
    Points: 1,201, Level: 7
    Join Date
    Nov 2006
    Posts
    Points
    1,201
    Level
    7
    at89c51.
    hi,
    i recommended you to read the book 8051 microcontroller by scott mackenze
  16. #16
    Junior Member level 1
    Points: 2,013, Level: 10
    Join Date
    Mar 2005
    Posts
    17
    Points
    2,013
    Level
    10
    microcontroller at89c51 basic
    hi
    i want to know between assamby and c what good to study
  17. #17
    Points: 1,126, Level: 7
    Join Date
    Mar 2007
    Posts
    16
    Points
    1,126
    Level
    7
    keil c programs at89c51
    8051 is easy to program. I suggest keil in order to program 8051. I has a lots of examples.
  18. #18
    Points: 1,323, Level: 8
    Join Date
    Mar 2007
    Posts
    29
    Points
    1,323
    Level
    8
    data logger at89c51
    i suggest you to use C language rather than asm. Because it's easier to learn. If you want to learn uC 8051, i think you can make digital clock. In the digital clock you will learn how to use I/O PORT in 8051, timer interupt and C-language. It's the basic project that you can make. You can use keil-C for it.
  19. #19
    Newbie level 5
    Points: 1,556, Level: 9
    Achievements:
    7 years registered
    Join Date
    Mar 2008
    Posts
    10
    Points
    1,556
    Level
    9
    how to write at89c2051 program in keil
    you may visit this site http://sainteknika.890m.com
  20. #20
    Full Member level 2
    Points: 2,220, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    India
    Posts
    126
    Points
    2,220
    Level
    10
    at89s51 projects by using microcontroller
    For the first time i suggest:
    1. toggle LED using your microcontroller
    3. use timer to control the brightness of your led
    4. try using LCD
    •   Alt31st March 2008, 07:19
      advertising
