+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Newbie level 6
    Points: 1,559, Level: 9
    Join Date
    Jul 2005
    Posts
    12
    Points
    1,559
    Level
    9
    direction finding + matlab code
    Hello,
    I need a matlab source code for the signal processing steps for direction finding. Or at least an algorithm for me to built a program.
    I'll be very thankful for the helps.
    thanks.
  2. #2
    Full Member level 5
    Points: 3,842, Level: 14
    Join Date
    Sep 2005
    Malaysia
    Posts
    309
    Points
    3,842
    Level
    14
    direction finding matlab code
    What direction is that? Can you describe more?
    •   Alt20th January 2006, 02:33
      advertising
  3. #3
    Newbie level 6
    Join Date
    Jul 2005
    Posts
    12
    Points
    1,559
    Level
    9
    matlab df direction finding
    sorry for not sufficent information.
    Direction finding (DF) refers to the establishment of the direction from which a received signal was transmitted.
    it is like estimation of the direction of a signal. it is an antennas and wave propagation problem but the estimation the direction of the signal is related with signal processing. hope i posted this topic in the right forum :)
    thanks
    •   Alt20th January 2006, 07:53
      advertising
  4. #4
    Newbie level 3
    Points: 1,943, Level: 10
    Join Date
    May 2002
    Posts
    Points
    1,943
    Level
    10
    try this article as a point of start (look for it at google)
    SDR_in_Direction_Finding_RFDesign_0105.pdf
    you can also search for DF basics, diferent implementations and solutions in the DSP field introducing the words "electronic warfare" in your google's searches. Luck!
    1 members found this post helpful.
  5. #5
    Newbie level 6
    Join Date
    Jul 2005
    Posts
    12
    Points
    1,559
    Level
    9
    wave propagation and direction finding
    thanks for the helps.
    Roshdy i'll appreciate if you can give me the Matlab codes.
    •   Alt22nd January 2006, 14:24
      advertising
  6. #6
    Member level 3
    Points: 4,169, Level: 15
    Achievements:
    7 years registered
    Roshdy's Avatar
    Join Date
    Nov 2005
    Egypt
    Posts
    58
    Points
    4,169
    Level
    15
    Re: direction finding
    attached one of my trials writing the MUSIC code which I could find
    I think it has some errors, it gets the number of signals but the spectrum needs some revision
  7. #7
    Newbie level 3
    Points: 1,241, Level: 7
    Join Date
    Feb 2006
    Posts
    Points
    1,241
    Level
    7
    Hi
    Try implementing the conventional beamformer (Delay and Sum) for Direction of Arrival Estimation and then go for the high resolution methods like MUSIC and ESPRIT.
    Conventional methods are relatively easy to implement
  8. #8
    Points: 12,348, Level: 26
    artem's Avatar
    Join Date
    May 2003
    Turkey
    Posts
    1,350
    Points
    12,348
    Level
    26
    direction finding
    There was a book "Radar systems analysis and design using matlab" . Should be available here or findable from emule .
  9. #9
    Points: 1,154, Level: 7
    Join Date
    Sep 2006
    kuala lumpur malaysia
    Posts
    Points
    1,154
    Level
    7
    direction finding
    do you have the link for that book
    •   Alt7th February 2008, 14:39
      advertising
  10. #10
    Newbie level 6
    Points: 2,138, Level: 10
    Achievements:
    7 years registered
    Join Date
    Nov 2006
    Islamabad, Paksitan
    Posts
    12
    Points
    2,138
    Level
    10
    available at gigapedia.org
  11. #11
    Newbie level 6
    Points: 115, Level: 1
    Join Date
    Nov 2013
    Posts
    14
    Points
    115
    Level
    Quote Originally Posted by Roshdy View Post
    hi.. will you share me your code for music..
