+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 1
    Points: 2,284, Level: 11
    mkw's Avatar
    Join Date
    May 2002
    Brazil
    Posts
    34
    Points
    2,284
    Level
    11
    How to invert rotation of VCA eletrical motor?
    Hi...
    I would like to invert the rotation of an electric motor.
    The motor is 120VCA, single phase and don´t use start capacitor.
    Thanks in advance
    MKW
    •   Alt13th February 2003, 21:50
      advertising
  2. #2
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    built in bias
    These motors have a built in bias for rotating in one direction caused by the construction of the field. If the motor is not too high a HP rating, you can mechanically rotate it the other way before applying the power and sometimes it will run backwards. Your best bet is to use some form of gearing or rubber wheels to mechanically change the rotation of an output shaft.
