+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Points: 1,275, Level: 8
    Join Date
    Jan 2006
    Posts
    Points
    1,275
    Level
    8
    connecting lcd to microcontroller
    Hi every body,
    I'm a computer engineering student, and I have a project..
    one part of this project needs to conect LCD or touch screen to a microcontrooler.
    I need help in this part, I can't imagin how would I program the LCD, and what should the scource code of the microcontroller be.
    Please Help me..
    and thanx alot..
    •   Alt15th January 2006, 11:18
      advertising
  2. #2
    Points: 1,622, Level: 9
    Join Date
    Dec 2004
    IRAN
    Posts
    Points
    1,622
    Level
    9
    lcd for microcontroller
    hi
    refer to :
    http://www.8052.com/tutlcd.phtml
    good luck
    2 members found this post helpful.
  3. #3
    Join Date
    Jan 2006
    Posts
    Points
    1,275
    Level
    8
    Thanx alot Eshragh,
    I will read it and I hope I will get benefit from it,thanx again...
    1 members found this post helpful.
    •   Alt15th January 2006, 14:18
      advertising
  4. #4
    Full Member level 2
    Points: 2,058, Level: 10
    Join Date
    Oct 2004
    Posts
    135
    Points
    2,058
    Level
    10
    connect lcd to 8051
    is it 44780 type? i hope it's standard lcd.
    You can access that type of LCD with 4 bit or 8 bit mode for the data. i think you should try the 8 bit first because it's easier. both of them on above site.
    Good luck
    •   Alt16th January 2006, 04:40
      advertising
  5. #5
    Join Date
    Jan 2006
    Posts
    Points
    1,275
    Level
    8
    how to connect microcontroller
    Thanx Rooftop for your reply,
    The previous Link was really helpful, thanx to Eshragh...
    The problem is that, I didn't select the LCD type yet, and I prefare to use touch screen but I'm afraid to face a big problems in it's programming!!
  6. #6
    Advanced Member level 1
    Points: 3,923, Level: 14
    Join Date
    Aug 2005
    Macedonia
    Posts
    440
    Points
    3,923
    Level
    14
    connecting a lcd to a microcontroller
    try this tutorial may help you. It's present connecting lcd to pic microcontroller.
    Regards
  7. #7
    Advanced Member level 2
    Points: 5,019, Level: 16
    Join Date
    Sep 2004
    Posts
    511
    Points
    5,019
    Level
    16
    connect an lcd to a microcontroller
  8. #8
    Newbie level 1
    Points: 666, Level: 5
    Join Date
    Mar 2009
    Posts
    Points
    666
    Level
    lcd connected to microcontrollers
    hi , how u doing
    i am final year student in electronic engneering.and i wanna help in some part ....
    i wanna know how to connect microcontroller with graphical LCD ....
    i was read this topic and i interrested to it ....
    could u help me
    thanx
  9. #9
    Full Member level 5
    Points: 2,953, Level: 12
    Join Date
    Aug 2003
    Posts
    243
    Points
    2,953
    Level
    12
    connecting lcd screen to pic microcontroller
    Hi Buddy,
    The main thing to find out is the type of LCD..
    Now a days LCD comes with lots of interface..ex: LVDS, RGB, TTL, DVI interfcae..
    now suppose if you are using LVDS interface LCD then you will need a chip like DS90C385A...
    a transreciver for converting the TTL signal into LVDS..
    if you are using VGA interfcae then you need analog transmisster and amplifer (depends upon the gain, load, SI)
    Analog Tx -ADV7125..
    LET ME KNOW THE TYPE OF LCD AND uC INTERFACE YOU ARE USING..
    THEN I CAN HELP YOU MORE..
    CHEERS,
    TOM
  10. #10
    Newbie level 1
    Points: 648, Level: 5
    Join Date
    Apr 2009
    Posts
    Points
    648
    Level
    microcontroller lcd
    Hi
    for pic micocontroller, check www.mikoe.com from this website you will be abel to read free books about pic microcontroller interface with LCD, and more...
    you can also free download mirobasic software and use its help you will find with details how to connect LCD with PIC
    that is my mail contact me for more help
    wahed.waal@yahoo.com
    regards
    wahed
  11. #11
    Junior Member level 2
    Points: 1,055, Level: 7
    Join Date
    Sep 2007
    South Africa
    Posts
    20
    Points
    1,055
    Level
    7
    how to interface lcd with 8535 microcontroller
    Hi all
    I have expwerience with standard alphanumeric displays connected to PIC micro-controllers. I am trying to get to grips with graphical LCDs now and have one made by EDT with the number 20-20420-2 sourced from Allen Bradley panelview 550. Does anyone know the pinout and any extra info for this? It has LC79401 and LC79430 ic on it. Thanks for your help!
    •   Alt29th April 2009, 11:08
      advertising
  12. #12
    Newbie level 5
    Points: 135, Level: 1
    Join Date
    Aug 2012
    Posts
    10
    Points
    135
    Level
    Re: How to connect LCD to microcontroller
    hello. i am making a project on gsm based lcd display. the major difficulty which i am facing right now is to interface my microcontroller with lcd display. I want to use 89s52 microcontroller and an lcd display of size maybe 40*2 or 80*2. can u pls tell me how will i interface my controller wid it. if possible the code also.
